DMC-1001EOL
ספק כח ליתירות עבור מארז ממירים DMC-1000
תאור
Module backup DMC-1001 for the DMC-1000 chassis ensures uninterrupted operation of media converters installed in the chassis. To improve reliability, the chassis can be equipped with two modules DMC-1001. In this case, the load will be distributed between the two power sources and the output of one of them fails, another immediately take over 100% load without any loss. Similarly, if one power supply is removed from the chassis, you can disable and remove from the chassis without loss of performance.
Features:
•  Protection: Over Voltage Protection, Short Circuit Protection.
•  Power distribution and redundancy.
• The signal failure of the fan: the power supply module will alert beep on possible fan failure. The refusal is based on reducing the fan speed.
מאפיינים כללים
תקנים
הורדות
איורים
DMC-1001/A4
מראה מקדימה
מראה מימין
Bottom view
Top view
דף מידע
ראה גם
