חיפוש מהיר
תכונות המוצר:
מודם-נתב ADSL אלחוטי בתקן g בעל 4 יציאות רשת קווית, תמיכה ב-QOS ו-2 יציאות USB 2.0 לשיתוף התקני אחסון ומדפסות רשת
דגם לא מיוצר יותר
מאפיינים כללים:
נתונים פיזיים
Interface Device
1-port ADSL connection with RJ-11
Integrated 4-port switch 10/100BASE-TX Fast Ethernet LAN RJ-45 with automatic polarity of MDI / MDIX
Built in 802.11g wireless interface
2-port USB 2.0
Wireless LAN
Standard IEEE 802.11g
Frequency range: from 2.4 GHz to 2.497 GHz
Connection speed: up to 54 Mbit /s
WEP-encryption 64/128-bit
Multiple SSID
Access control list (ACL) on the basis of MAC-addresses
Security WPA/WPA2 with TKIP and AES support
Support WDS
802.11e WLAN QoS (WMM / WME)
On / off wireless switch
ADSL Standards
ADSL: Full-rate ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G.hs )
ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A / L / M, ITU-T G.992.4 (G.lite.bis) Annex A
ADSL2 +: ITU-T G.992.5 Annex A / L / M
Connection speed
ADSL2 +: up to 24 Mbps downstream with the flow, up to 1 Mbps upstream flow
Protocols ATM / PPP
Multiprotocol encapsulation over AAL5
Encapsulation Ethernet Bridged and routed Encapsulation LLC
Multiplexing on the basis of the virtual channel (VC-based multiplexing)
ATM Forum UNI3.1/4.0 PVC
ATM Adaptation Layer Type 5 (AAL5)
ITU-T I.610 OAM F4/F5 loopback
ATM QoS (Traffic Shaping)
PPP over ATM
PPP over Ethernet
Network protocols and functions
Static IP-routing
RIP
NAT
Virtual server, redirecting ports
DHCP-server/klient/relay
DNS Relay, DDNS
IGMP proxy
SMTP
Firewall / Access Control
NAT firewall
MAC-address Filtering
Packet filtering (IP / ICMP / TCP / UDP)
Stateful Packet Inspection (SPI)
Preventing DoS attacks
Intrusion Detection System and logging DMZ
VPN
Multiple IPSec/PPTP/L2TP pass-through
QOS
Mainstreaming / classification of traffic based on:
Ports
802.1p priority queues
Application Ports
Priorities defined by user (TCP / UDP / ICMP etc.)
3 priority queues on PVC
PVC / VLAN port mapping
IGMP v.2 snooping
Setting / Managing
Quick Installation Wizard
Web-interface
Download software via the Web-interface / TFTP, load / save configuration
SNMP v1, v2c, built-MIB-I, MIB-II
TR-069
Button reset to factory settings
WPS Button
On / off switch module Wireless
Indicators
Power
DSL
WLAN
LAN (1-4)
Internet
USB 1 and 2
Physical parameters
operating Through external power adapter: 12V DC 1.5 A
Switch power ON / OFF
Dimensions
114 x 31 x 191 mm
Weight
350 g
Operating temperature
From 0 ˚ to 40 ˚ C
Storage Temperature
From -20 ˚ to 65 ˚ C
Working humidity
From 5% to 95% non-condensing
Certificates
FCC Part 15 Class In
CE (EN55022/EN55024/EN300 328 /
EN301 489)
Safety
CSA
LVD
FCC part 15 class B
CE class B
RoHS complaint
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
