ANT24-0802
Omni-Directional Antenna, 8 dBi
היכן לקנות
תאור
The ANT24-0802 omni-directional antenna with 8 dBi gain operates in 2.4 - 2.483 GHz frequency band and has RP-SMA Plug connector.
The ANT24-0802 antenna connects to a wireless device equipped with detachable antennas, for example access point or router. The 8 dBi ANT24-0802 antenna allows you to extend the 2.4 GHz wireless network coverage and improve the quality of signal reception/transmission. This antenna is designed for indoor use.
מאפיינים כללים
Connector
• RP-SMA Plug
Frequency band
• 2.4 GHz - 2.483 GHz
Gain
• 8 dBi
VSWR
• 2.0 : 1 Max.
Polarization
• Linear, vertical
HPBW / horizontal
• 360°
HPBW / vertical
• 24°
Impedance
• 50 Ohms
Power handling
• 10 W
Lightning protection
• DC Ground
Physical Parameters
Dimensions
• Length: 280 mm
• Diameter: 66 mm
Weight
• 0.3 kg
Environmental Conditions
Survival wind speed
• 180 km/hr
Operating Temperature
• -40 to 80 °C
Operating Humidity
• 100% @ 25 °C
נתונים פיזיים
תקנים
הורדות
ANT24-0802 Omni-Directional Antenna, 8 dBi
איורים
ANT24-0802
מראה מקדימה
דף מידע
ראה גם
