ANT24-1201EOL EOS
תאור
Directional external passive antenna Yagi type D-Link ANT24-1201 connects to wireless devices operating in the frequency range of 2.4 GHz to increase the area of wireless coverage.
The antenna is made of weather resistant material phenomena.
The antenna is supplied with a cable - adapter, allows you to connect the antenna to the wireless device has a reverse plug SMA.
Scope of supply consists of a set of fasteners, power lightning protection and grounding cable - adapter.
מאפיינים כללים
Frequency band
2.4 - 2.5 GHz
Signal amplification
12 dBi
VSWR
1 5 max
Polarization
linear vertical
HPBW
Horizontal 50o
Vertical 50o
Ratio of the front to the back of the
15 dB
Power supplied to the antenna input
50 W
Resistance
50 ohms
Jack
N - type "mother"
Cable adapter
N-«Dad" in the RP-SMA, length 50 cm
Theoretical transmission distance at a speed of 1 Mbit/s/11 Mbit / s (when using the internal access points) *
1.5 km/500m
Theoretical transmission distance at a speed of 1 Mbit/s/11 Mbit / s (when working with external access points) *
2.5 km/1km
