DAP-1620EOL
מגדיל טווח אלחוטי דואל-בנד בתקן AC1200
היכן לקנות
תאור
The DAP-1620 AC1200 Wi-Fi Range Extender is a portable plug-in repeater that lets you extend an existing wireless network. You can place it anywhere in your home to increase the range of your wireless network. Tiny yet powerful, it supports Wireless AC speeds of up to 1200 Mbps, yet fits in the palm of your hand.
Extend Your Wireless Network
Increase the coverage of your home Wireless AC network with the sleek and easy-to-use DAP-1620 AC1200 Wi-Fi Range Extender. Dual-band technology helps reduce interference from nearby wireless transmitters in the home, and also provides backward compatibility with older wireless devices in your network, allowing you to enjoy a blazing-fast, reliable wireless connection. Alternatively, use the built-in Gigabit Ethernet port and your home’s existing wired Ethernet cabling to extend wireless coverage without worrying about signal strength.
Easy to Set Up, Easy to Use
Setting up the AC1200 Wi-Fi Range Extender is simple. You can use the supported QRS Mobile app on your iPhone, iPad, or iPod touch or Android mobile device to set up the DAP-1620 easily without needing a computer. Alternatively, you can use one-touch con configuration by pushing the WPS push-button on the DAP-1620 and on the router or AP you want to extend, and the DAP-1620 will automatically configure itself for you. It even includes a built-in setup wizard that lets you configure it wirelessly with a PC or mobile device.
Compact, Convenient Design
The DAP-1620 is a compact device that is ideal for use at home or a small office, as it does not take up much space and is ready to use by simply plugging it in. The bright Signal Indicator LED makes findnding a suitable location a cinch. Its diminutive wall-plug design easily saves you the hassle of dealing with a power cord. Its sleek, unobtrusive appearance blends easily into the decor of your home or office.
מאפיינים כללים
Interfaces
• 802.11 ac / n / g / b / a Wireless LAN
• 10/100/1000 Gigabit Ethernet-port
Indicators
• Power / Status
• Three-position indicator of the level of the received Wi-Fi signal
Button
• Reset Button
• WPS button
Antenna
• Two external antenna with a gain of 2 dBi (2,4 GHz / 5GHz)
Power connector
• Power connector
Standards
• IEEE 802.11ac
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.11ab
Frequency band
• 2400 MHz - 2483 MHz
• 5150 MHz - 5350 MHz
Wireless security
• Secure access Wi-Fi (WPA / WPA2)
• WPS (PBC)
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit / s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11n (2,4 GHz / 5 GHz):
Device control
• Support QRS Mobile app for iPhone, iPad, iPod devices based on Android
• Custom Web-based interface
Network control
• Web-interface
Modes
• Repeater
• Access point
Supported functions
• WPS (Wi-Fi Protected Setup)
Wireless security
• WPA
• WPA2
Standards
• IEEE 802.3i
• IEEE 802.3u
• IEEE 802.3ab
• IEEE 802.3x
נתונים פיזיים
• Weight 139 g
• Dimensions 95 x 63 x 41 mm
• Operating voltage 220 V
• Maximum power consumption 4,3 W
Temperature
• Operating: 0 ° to 40 ° C
• Storage: -20 ° to 65 ° C.
Humidity
• Storage: 5% to 95% non-condensing
Certifications
• FCC
• IC
• CE
• C-Tick
• EMI / EMC
• UL
• Wi-Fi Certified
תקנים
הורדות
איורים
DAP-1620
מראה מקדימה
מראה מימין
מראה מימין
דף מידע
ראה גם
