חיפוש מהיר
תכונות המוצר:
בקר אלחוטי לניהול נקודות גישה מבוסס תוכנה - D-Link Central WiFiManager
תאור:
A simple solution for the remote management of wireless infrastructure
Central WifiManager is a free software controller for centralized control of wireless networks of small, medium and large enterprises. With it, administrators can remotely manage hundreds of access points, regardless of where they are currently located. For more effective management controller supports remote configuration of wireless network settings, monitor the network in real-time, secure authentication on the guest portal, automatic adjustment of the frequency plan and transmit power, the ability to group firmware upgrade and configuration of access points.
Management access from anywhere
The program controller D-Link can be installed in a local network or on a remote cloud platform. This solution allows the administrator to connect to the server and control the operation of devices from anywhere in the world where there is Internet access. Supports administration by multiple users with different levels of access.
Managed network of 1,000 points of access
Unlike hardware controllers, program the controller D-Link Central WiFiManager free of charge in the case of expansion of the wireless network does not require the purchase of additional licenses to increase the number of managed APs. Since the controller can control the operation of the access points 1000¹ D-Link regardless of where they are located. Among the supported models - DAP-2330 and DAP-2360 / B1 class N300, dual-band access point DAP-2690 / B1 class N600, DAP-2660 class AC1200, DAP-2695 class AC1750, and external dual-band access point DAP-3662 class AC1200 .
Ease of use
The administrator has access to the Central WiFiManager through the Internet from your computer, smartphone or tablet anytime, regardless of location. Configuring and managing a wireless network implemented by a simple and easy-to-use Web-based interface, which is available in Russian.
Enterprise-class Functionality
The controller is designed to meet the highest demands of modern business and offers a range of enterprise-level features, including:
authentication via external RADIUS servers, or LDAP, the ability to control radio frequencies to switch access points to the less loaded channel the automatic power settings to improve performance wireless network the ability to automatically eliminate "dead zones" in the event of failure of one of the TD Managed by increasing the capacity of the neighboring
load balancing between bands for dual-band TD.
Portal authentication for users of the visited network
The program controller supports differentiation of network traffic - domestic worker and the guest. A special portal allows full control of the visited network, and block access to the clients not authenticated.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
