חיפוש מהיר
תכונות המוצר:
נקודת גישה אוניברסלית אלחוטית, עם תמיכת PoE, בתקן 802.11n עד 300Mbps
EOL EOS
מאפיינים כללים:
System
• Wireless Interface: 802.11b/g/n (2,4 / 5 GHz)
• Interface LAN: 10/10/100 Gigabit Ethernet
• Console: RJ-45
• Antenna: Built-in 2x2 MIMO antenna with external antenna connectors 4
• Antenna Gain: 4,7 dBi
• Supply: IEEE 802.3af Power Over Ethernet or external power adapter
Frequency
• 802.11n: 2,4 GHz - 2.497 GHz and 4.9 GHz - 5.85 GHz
• 802.11b / g: 2,4 GHz - 2.485 GHz
Data transfer rate
• 802.11n
  6.5 Mbit / s - 130 Mbit / s (20 MHz)
  6.5 MHz - 300 Mbit / s (40 Mbit / s)
• 802.11b: 11, 5.5, 2 and 1 Mbit / s
Transmitter output power
• 802.11b: 13 (+ / -2) dBm at 11,5.5, 2 and 1 Mbit / s
• 802.11n (2,4 GGts/HT-20): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (2,4 GGts/HT-40): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (5 GGts/HT-20): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
• 802.11n (5,0 GGts/HT-40): 11 dBm at MCS0 / 8, MCS1 / 9, MCS2/10, MCS3/11, MCS4/12, MCS5/13, MCS6/14, MCS7/15
Receiver Sensitivity
• 802.11b
  -92 (+ / -2) DBm at 1 Mb / s
  -90 (+ / -2) DBm at 2 Mbit / s
  -88 (+ / -2) DBm at 5.5 Mbit / s
  -85 (+ / -2) DBm at 11 Mbit / s
• 802.11g
  -87 (+ / -2) DBm at 6 Mbit / s
  -87 (+ / -2) DBm at 9 Mbit / s
  -85 (+ / -2) DBm at 12 Mbit / s
  -82 (+ / -2) DBm at 18 Mbit / s
  -79 (+ / -2) DBm at 24 Mbit / s
  -76 (+ / -2) DBm at 36 Mbit / s
  -71 (+ / -2) DBm at 48 Mbit / s
  -67 (+ / -2) DBm at 54 Mbit / s
• 802.11n
 2.4 GGts/HT-20
  - 85dBm at MCS0 / 8
  - 82dBm at MCS1 / 9
  - 80dBm at MCS2/10
  - 77dBm at MCS3/11
  - 74dBm at MCS4/12
  - 69dBm at MCS5/13
  - 68dBm at MCS6/14
  - 65dBm at MCS7/15
 2.4 GGts/HT-40
  -82 DBm at MCS0 / 8
  -79 DBm at MCS1 / 9
  -77 DBm at MCS2/10
  -74 DBm at MCS3/11
  -71 DBm at MCS4/12
  -66 DBm at MCS5/13
  -65 DBm at MCS6/14
  -62 DBm at MCS7/15
 5.0 GGts/HT-20
  - 85dBm at MCS0 / 8
  - 79dBm at MCS1 / 9
  - 77dBm at MCS2/10
  - 74dBm at MCS3/11
  - 70dBm at MCS4/12
  - 66dBm at MCS5/13
  - 65dBm at MCS6/14
  - 64dBm at MCS7/15
5.0 GGts/HT-40
  -79 DBm at MCS0 / 8
  -76 DBm at MCS1 / 9
  -74 DBm at MCS2/10
  -71 DBm at MCS3/11
  -67 DBm at MCS4/12
  -64 DBm at MCS5/13
  -63 DBm at MCS6/14
  -62 DBm at MCS7/15
Security
• SSID:
  + 16 SSID, SSID 32 to the access point
  + Isolation of Station
• Security: WEP, Dynamic WEP, WPA Personal / Enterprise, WPA2 Personal / Enterprise
• Detection and Prevention: Classification of access points to the unauthorized and authorized
• Authentication: Filtering by MAC-addresses, 802.1x
System control
• Web-User Interface: HTTP / HTTPS
• Command line: SNMP, SSH, Telnet
נתונים פיזיים
Power
• Power adapter: 12V / 1A
• Power over Ethernet: 48 VDC + / - 10%
Type of housing
• Plastic housing or housing class Plenum
Body size
• 77,5 x 156 mm
Weight
• 0.5 kg
Operating temperature
• From 0 ˚ to 40 ˚ C
Operating Humidity
• From 10% to 90% noncondensing
Security
• cUL, LVD (EN60950-1), UL20432
Certificates of EMI / EMC / RF
• FCC Class B, CE Class B, C-tick, IC, VCCI, NCC, TELEC, Wi-Fi ®
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
