ANT24-1600NEOL EOS
תאור
Directional Antenna D-Link ANT24-1600N Dual polarization for outdoor use can increase the range of the wireless LAN, operating in the 2.4 GHz band. The antenna can provide high-speed connection when connecting to devices standard 802.11n. ANT24-1600N is equipped with two connectors for the transmission of two-dimensional flows.
Point to Point Mode
ANT24-1600N is ideal for use in these regimes, as a point-to-point (WDS), as well as in other modes, where a directional antenna with high gain. The antenna enables the expansion of local area network by combining the two networks LAN, separated physically. Alternatively, customers WISP (Wireless Internet Service Provider) may also use this antenna to install a secure connection between the host and the external access point provider.
Resistance to weather influences
Antenna ANT24-1600N is made waterproof, rugged housing, the appropriate standard of IP67 and provides reliable protection against environmental influences. Moreover, the body is made of material resistant to corrosion and capable of withstanding harsh climatic conditions and wind speeds up to 216 km / h, ensuring reliable operation in a lifetime. Surge Arrestor ANT70-SP can be purchased separately to protect the receiver from the antenna electrical voltages that can cause damage and other elements of the external influences such as lightning.
Flexibility of installation
To install the antenna ANT24-1600N supplied antenna comes with a mount that provides the installation of antennas on the mast to provide enhanced wireless coverage. The package also includes a cable adapter with the N-type connectors, and RP-SMA for easy connection to the host.
מאפיינים כללים
Frequency band
• From 2.4 GHz to 2.5 GHz
Resistance
• 50 ohm
Gain
• 11dBi (2.4 GHz frequency range)
VSWR
• 2.0: 1 (max)
Maximum gain
• 16-17 dBi
Diagram in the horizontal plane (HPBW / H-PLANE)
• 18 ° - 25 °
Diagram in the vertical plane (HPBW / V-PLANE)
• 18 ° - 25 °
Polarization
• Linear, vertical / horizontal
Ratio of front and rear signal levels (PPE)
• -25dB (max.)
Cross-polarization isolation
• 16dB (minimum)
