חיפוש מהיר
תכונות המוצר:
מתאם רשת אלחוטי Wireless 150 עד 150Mbps
EOL EOS
תאור:
High-speed wireless network connection
When connected to a high-speed wireless network using a USB-adapter, the D-Link Wireless 150, you can browse web-pages, check e-mail, chat with friends and family online. Wireless Technology 150 offers increased wireless speed and range compared with the standard 802.11g/b, ensuring fast and reliable wireless connection.
Extended Range USB-adapter DWA-127 with an antenna having high gain, and improves signal reception, and it provides increased wireless coverage. Due to the possibility of rotation of the antenna can improve reception of the wireless signal with a fine-tuning the antenna.
Secure connection to a wireless network
To protect user data and confidential information while browsing web-pages, DWA-127 supports encryption protocols WEP, WPA and WPA2 to connect to protected wireless networks and ensure the safety of the traffic. This allows you to safely and confidently make purchases at online store and check mail.
Easy to install and use
Using the Quick Setup Wizard for a few minutes to install USB-adapter. Technology Wi-Fi Protected Setup (WPS) provides a secure wireless connection without requiring the user to complicated settings.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
