Mini Adapter PowerLine AV DHP-208AV HomePlug AV compliant and uses the existing home electrical wiring to create a network or extend an existing network.1 This adapter is connected to a power outlet, turns it into an access point and allows you to access digital media devices, game consoles, print servers, computers and network storage devices throughout your home without the need for additional wiring.
Easy installation and safety
DHP-208AV plugs directly into a power outlet and does not require any additional cables. Thus, using the house any power outlet, you can instantly gain access to the network connection. Expand your home network by connecting multiple devices from the most distant points of the house. Organize share an Internet connection using a media center in the living room or connect computers in different rooms to share files without running new cabling. For ease of installation encryption key can be quickly configured with the click of a button. The adapter supports 128-bit AES encryption to protect your network from unauthorized connection to the line and to ensure safe operation of the network.
High speed data transmission over existing electrical wiring
PowerLine AV technology provides data transfer rates up to 200 Mbit / s, providing bandwidth for today's demanding multimedia applications. Create a network for Internet and file sharing using existing home wiring.
Automatic energy saving
DHP-208AV supports the power saving mode to reduce its consumption, when the network is not used. If within a period of time not being transmitted or received, the adapter automatically switches to standby mode, reducing power consumption by more than 70% and providing automatic energy savings without sacrificing performance.
Compact size and discreet design
Due to its small size DHP-208AV adapter fits easily in a home environment and not be evident. Stylish white shell device makes it invisible, and due to the small size, access to nearby food outlets will not be difficult.
Starter kit PowerLine AV DHP-209AV
DHP-208AV adapter is also available in the kit, which provides a turnkey solution PowerLine. Starter kit PowerLine AV DHP-209AV includes two mini-adapter DHP-208AV, allowing to create a home network PowerLine.
