חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת אלחוטית באיכות HD עם זוית צילום 180 מעלות וצילום לילי
דגם לא מיוצר יותר
מאפיינים כללים:
Interfaces
•  microSD card slot
Indicators
• Power / status
Button
• WPS button
• Reset Button
Power connector
• microUSB connector for power supply (DC)
Main characteristics
• 1 / 2.7 inch megapixel CMOS-sensor with progressive scan technology
• Focal length: 1.72 mm
• Aperture: F2.0
• Minimum distance to the object: 500 mm
• Viewing angle:
- 180 ° (horizontal)
- 120 ° (vertical)
- 180 ° (diagonal)
• Minimum illumination:
- Color mode: 0.5 lux
- Black and white mode: 0.1 lux
- Black-and-white mode with infrared illumination: 0 Lux
• Distance infrared light: 5 m
• Built-in ICR filter
• 8x digital zoom
• Eliminating image distortion
• Built-in microphone
Specifications image
• Setting the image size and quality, frame rate and bit rate
• Adjust the brightness, contrast, sharpness, color saturation and hue
• Customizable windows for motion detection
• Time stamp and text insertion
Video compression
• Compression formats H.264 / MJPEG
• JPEG for still pictures
Video resolution
• 1280 x 720, 800 x 600, 720 x 480, 640 x 480, 640 x 360, 320 x 240 and 30 frames / s
Audio
• G.711
Network protocols
• IPv4, ARP, TCP, UDP, ICMP
• DHCP-Client
• NTP-client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• FTP-client
• HTTP-server
• PPPoE
• RTP, RTSP, RTCP
• UPnP Port Forwarding
• HTTPS for configuration
• Bonjour
Security
• Protection of the Administrator account and user group
• Password authentication
• HTTP and RTSP Authentication
Wireless module
• 802.11ac / n / g / a with WEP / WPA / WPA2 encryption
• Work in the frequency bands 2.4 GHz and 5 GHz
• Wireless connection speed of up to 433 Mbit / c1 for the 5 GHz band
Event management
• Motion Detection
• Detection of sound
• Event notification and downloading still images / video clips via e-mail or FTP
Remote control
• Interface settings available through the Web-browser
Mobile device management
• mydlink Lite app for iPhone, iPad, iPod Touch, mobile devices based on Android and Windows Phone
• mydlink + app for iPad and mobile devices based on Android
System requirements for Web-based
• Operating System: Microsoft Windows 7/8/10 or Mac OS X 10.7 or higher
• Web-Browser: Internet Explorer 8, Firefox 12, Safari 6 or higher
נתונים פיזיים
Weight
• 165 g ± 5%
Dimensions
• 137.5 x 95.8 x 95.8 mm
Power
• 5 V DC, 2 A, 50/60 Hz
Power consumption
• Max. 4.8 W ± 5%
Temperature
• Operating: 0 to 40 ° C
• Storage: -20 ° to 70 ° C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 20% to 80% (non-condensing)
Package contains
• Network Camera DCS-960L
• Camera Stand
• Power adapter
• Mounting kit
• Warranty Card
• Quick Installation Guide
• Quick Setup Card
Certifications
• CE
• CE LVD
• FCC Class B
• ICES
• C-Tick
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
