חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת בצורת כיפה עם צילום לילי צבעוני
EOL EOS
מאפיינים כללים:
Camera Hardware Profile
• 1/3” Megapixel progressive CMOS sensor
• 15 meter IR illumination distance
• Built-in Infrared-Cut Removable (ICR) Filter module
• Minimum illumination:
• 0.1 Lux Color mode
• 0.02 Lux Black and White mode
• 0 Lux Black and White mode with IR LED on
• Minimum object distance 0.2 m
• 2.8 to 12mm variable focal lens
• Aperture F1.4
• Angle of view (16:9)
  (H) 90° to 28°
  (V) 58.8° to 16°
  (D) 103° to 33°
Camera Housing
• IP-68 compliant weatherproof housing
• IK-10 compliant vandal-proof housing
• Included weathershield
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable exposure time, brightness, saturation, contrast, sharpness
Video Compression
• Simultaneous H.264/MPEG-4/MJPEG format compression
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176 at up to 30 fps
• 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240 at up to 30 fps
Audio Support
• G.726
• G.711
External Device Interfaces
• 10/100 BASE-TX Ethernet port with PoE
• 1 DI / 1 DO
• DC12 V, 400 mA Output
• micro SD/SDHC/SDXC card Slot, accepts cards up to  64 GB
• Audio input / output
Network Protocols
• IPv6
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP / HTTPS
• Samba client
• PPPoE
• UPnP port forwarding
• RTP / RTSP/ RTCP
• IP filtering
• QoS
• CoS
• Multicast
• ONVIF compliant
• SNMP
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Chrome, Safari
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive
• Configuration interface accessible via web browser
OS Support
• Windows 2000/XP/Vista/Windows 7/8/iPhone/iPad/Android
D-ViewCam™ System Requirements
• Operating System: Microsoft Windows 8/7/Vista/XP
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCam™ Software Functions
• Remote management/control of up to 32 cameras
• Supports all management functions provided in web interface
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
נתונים פיזיים
Weight
• 1112 grams
Power
• Input: 100 to 240 V AC, 50/60 Hz
• Output:  12 V DC 1.5 A
Power Consumption
• 12.24 +/- 5% watts
Temperature
• Operating: -30° to 50°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
