חיפוש מהיר
תכונות המוצר:
שרת NVR עם מקום לדיסר אחד עם חיבוריות ל mydlink
EOL EOS
מאפיינים כללים:
Standards
• IEEE 802.3/u/z
• Auto MDI/MDI-X
• SATA I, II, III
HDD
• Reformat Disk
• Up to 4TB HDD*
• EXT3 file system
Two Reset Modes
• Reset firmware GUI button
• HW reset button (hold for 10 seconds)
Reset Button
• Reset to factory default
Flash ROM
• 128 MB
RAM
• 1024MB DDR III
Network Interface
• Gigabit Ethernet LAN port (10/100/1000 Mbps)
I/O Ports
• RJ-45 port
• DC-in jack
• HDMI
• 2 x USB 2.0 port (Mouse, UPS, Flash Disk, HDD with external power)
• 3.5mm audio input x 1, output x 1
Power Adapter
• DC 12 V/3 A
OS
• Linux
Supported Cameras
• Supports all D-Link network cameras and megapixel resolution
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Chrome, or Safari
Recording Performance
• First video profile:
• H.264 at 720p at 270 fps
• Secondary video profile:
• H.264 at VGA at 135 fps
Camera Search
• UPnP
Audio and Video Recording
• Synchronized audio & video recording
Compression Format
• H.264, MPEG-4, M-JPEG
Video Setting
• Resolution, quality, frame rate, enable audio, go to camera interface
Recording Type
• Record by schedule, manual, and event-based recording
• Motion-triggered recording
Remote Live View
• Supported via browser
• Supports mydlink portal
Remote Live View Control
• Live view, preset/go, patrol, focus, PTZ functions, snapshot, full screen, digital zoom
• e-map
Remote Playback Control
• Playback with normal, fast forward/rewind and step forward/rewind
Remote Playback
• Supported via browser and NVR client
• Playback system with timeline GUI, search by event, area, cameras, date, and time
• Browser or NVR Remote Client support four channel simultaneous playback
• Digital zoom
Overwrite Recording
• Auto recycling when disk storage is full
File Export
• Local : Export videos to AVI
• Remote: Export videos to AVI or ASF file
• Export images to BMP or JPG file
User Account
• Additional accounts can be created to allow users system access and specify authorization for camera channels, PTZ
DDNS
• D-Link DDNS and DynDns server support
System Time
• Set the system time (D-Link NTP, input time, sync with computer, Daylight Saving Time)
Remote Backup
• Remote backup software can backup raw data to redundant storage
System Status
• Camera status
• System status
Network Service Protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP Client
• NTP Client
• DNS Client
• DDNS Client
• SMTP  Client
• FTP Client
• HTTP Server
• IP filtering
• UPnP
• HTTPS
• Bonjour
• SNMP
User Interface
• HTTP Web browser
• mydlink portal
• Smart phone
• NVR Search utility
Package Contents
• mydlink One-bay standalone NVR
• Power Adapter
• Ethernet Cable
• Quick Installation Guide
• CD-ROM with:
  Software
  Product Documentation
נתונים פיזיים
Weight
• 0.425 kg
Maximum Power Consumption
• 30 W
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• 5% to 90% non-condensing
Certifications
• CE
• FCC
• RoHS
• BSMI
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
