חיפוש מהיר
תכונות המוצר:
מארז חיצוני למצלמות DCS-31xx, DCS-37xx
תאור:
Series enclosures D-Link DCS-56 is a versatile and cost-effective solution for the installation of surveillance cameras D-Link outside. Model DCS-56P supports Power over Ethernet (PoE), and the model DCS-56W enables wireless connections, providing convenient connections and observations. Housing with integrated power supply, heater and fan provides performance camera in adverse weather conditions.
Connection flexibility
DCS-56P supports Power over Ethernet (PoE), capable of transmitting power and data over a single cable Ethernet. PoE support enables you to place cover in different places without running additional power cables. The presence of the antennae cover DCS-56W significantly enhances connectivity and provides remote control and monitoring without the need for laying Ethernet cable.
Weatherproof housing
Designed for mounting the camera outdoors, the series covers DCS-56 is an all-weather enclosure (standard IP66), protecting the camera from dust and rain.
Built-in heater and fan
Series covers DCS-56 has a built-in heater and fan for the camera work in a wide temperature range. Heater and fan on and off automatically when the temperature is below or above a certain threshold.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
