חיפוש מהיר
תכונות המוצר:
שרת NVR עם מקום ל 2 דיסקים ותמיכה ב mydlink
EOL EOS
מאפיינים כללים:
Software
• Linux operating system
Supported Cameras
• Supports all network cameras D-Link. Also supports automatic detection and resolution of 3 Megapixels.
Characteristics of writing
• Max. performance (only NVR):
  + H.264 1080P (baud rate): 90 Mbit / s
  + H.264 720P (baud rate): 90 Mbit / s
  + MJPEG 1080P (fps): 90 fps
  + MJPEG 720P (fps): 192 fps
• Max. performance (NVR + file server):
  + H.264 1080P (baud rate): 68 Mbit / s
  + H.264 720P (baud rate): 68 Mbit / s
  + MJPEG 1080P (fps): 70 fps
  + MJPEG 720P (fps): 150 fps
Search for the camera
• UPnP
Record audio and video
• Simultaneous recording of audio and video
Compression format
• H.264, MPEG-4, M-JPEG (on supported cameras)
Video settings
• Resolution, quality, frame rate, the inclusion of audio, the transition to the camera interface
Type of record
• Scheduled recording, manual or event-
• Motion Detection Recording
• Remote viewing of video in real time
• Support for remote viewing via Internet Explorer (maximum number of channels - 9)
• Portal mydlink (Max number of channels - 1)
Managing remote video in real time
• Video in real time, preset (preset) / go (go), patrolling, focus, function PTZ, snapshot, full screen mode, digital zoom, e-map, Simultaneous display (1/4/6/9/16/25 / 36/48) channels
Managing remote playback
• Playing with the normal functions of rewind, fast forward / backward and step forward / backward
Remote playback
• Playing through Internet Explorer and the NVR-client
• The system of play with the scale of time, searching for the event, area, cameras, date and time
• IE and NVR-client support playback of a single channel
• Digital zoom
Function Overwrite (overwrites)
• Auto recycling when filling the space on your hard drive
Exporting files
• Export video to AVI or ASF
• Export images in BMP or JPG format
A user account
• Creating additional user accounts to allow users access to the system, as well as set the authorization for the channels cameras, PTZ, etc.
System time
• Setting the system time (D-Link NTP, enter the time manually synchronizing with the computer, the mode of Daylight Saving Time)
DDNS
• Support DDNS-server D-Link
Remote backup
• Remote software can create a backup copy of the raw data on a secondary storage device
• Automatic backup of videos from previous days on the FTP-Server
System status
• Position the camera system status
• Support for EMAP
Network protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP-client
• NTP-client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMPT-client
• HTTP-server
• PPPoE
• UPnP
• Filtering of IP-addresses
User interface
• Web-portal Mydlink - Internet Explorer v6 or higher
• HTTP Web-browser - Internet Explorer 7 or higher (32 bit)
• NVR Search Tool
Hardware Specifications
Standards
• IEEE 802.3/u/z
• Auto MDI / MDI-X
• SATA I, II
HDD (hard disk) 1
• Control and management of the hard drive from a computer
• Reformatting a hard disk
• RAID 02
• RAID 12
• JBOD
Two modes of reset
• Reset through a Web-based interface
• Reset by pressing on the body (hold for 5 seconds)
Flash ROM
• 128 MB
RAM
• 128MB DDR II
Network Interface
• LAN-port Gigabit Ethernet (10/100/1000 Mbit / s)
I / O ports
• RJ-45 port
• DC-in jack
• USB-port for updating the status of the UPS (optional)
נתונים פיזיים
Power consumption
• Max. Power Consumption: Tues 25.20
• Max. power consumption mode, standby: 0,23 Tues
Dimensions
• 115 x 146.4 x 178.5 mm
Weight
• 0.875 kg
Operating temperature
• From 0 ˚ to 55 ˚ C
Storage temperature
• From -20 ˚ to 70 ˚ C
Humidity
• 5% to 90% (no condensation)
Certificates
• CE
• FCC
• RoHS
Delivery
• Video Recorder NVR
• Power Adapter
• Ethernet cable
• Quick Installation Guide
• Clamp the power cable
• CD-ROM c:
   + Software
   + Documentation for the product
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
