Hardware Profile
1/4” Megapixel progressive CMOS sensor
15 meter IR illumination distance
Built-in Infrared-Cut Removable (ICR) Filter module
4 mm fixed lens , F1.5 with 65.4 degree horizontal viewing angle
256 Mbytes SDRAM
128 Mbytes of flash memory
Image Features
Configurable image size, quality, frame rate, and bit rate
Time stamp and text overlays
3 configurable motion detection windows
Min Illumination: 0.26 Lux (day mode), 0 Lux (night mode) with IR LED
5 configurable privacy masks
Flip & mirror
Configurable white balance, shutter speed, brightness, saturation, contrast, sharpness
Video Compression
H.264/MPEG4/MJPEG format compression simultaneously
JPEG for still image
H.264/MPEG-4 multicast streaming
Video Resolution
1280x800 @ 30 fps
1280x720 @ 30 fps
640x480 @ 30 fps
320x240 @ 30 fps
176x144 @ 30 fps
Network Protocols
IPv4, IPv6, TCP/IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding, RTP / RTSP/ RTCP, IP filtering, 3GPP, LLTD, CoS/QoS, SNMP, IGMP, 802.1x, ONVIF Compliant
Security
Administrator and user group protection
Password authentication
HTTP and RTSP digest encryption
HTTPS streaming
Event Management
Motion detection
Event notification and upload snapshots/video clips via HTTP,
SMTP or FTP
Supports multiple HTTP, SMTP and FTP servers
Multiple event notification
Multiple recording methods for easy backup
Remote client access control
Surveillance Software Function
Remote management/control of up to 32 cameras
Viewing of up to 32 cameras on one screen
Supports all management functions provided in web interface
Scheduled motion triggered, or manual recording options
Supported PDA, Mobile Phones, and Software
Handsets with 3GPP player, Packet Video Player 3.0, QuickTime 6.5, Real Player 10.5, Windows 2000, XP
