חיפוש מהיר
תכונות המוצר:
מצלמת מעקב אלחוטית בתקן 802.11n באיכות HD עם מנוע מכני
EOL EOS
תאור:
Multi-camera for video surveillance
Wireless 802.11n HD video camera with tilt and rotate the drive D-Link DCS-5222L is the ideal solution for small and medium-sized businesses, as well as remote monitoring via the Internet. DCS-5222L provides detailed clock remote monitoring of a vast territory, using the HD megapixel sensor for high-quality high-definition video and built-in infrared illuminator for video surveillance in low light conditions. DCS-5222L can also connect to a wireless network that allows you to place the camera anywhere without the need for network cables.
A powerful video surveillance system
DCS-5222L provides embedded processor that allows you to use the camera as a standalone security system. Recording can be done continuously, by motion or in accordance with the established schedule. In the case of certain events, you can send e-mail notification, which allows the user to be aware of what is happening. Built-in microSD card slot allows the camera to work regardless of network connection or can be used for continuous video recording, even if the network connection is lost. DCS-5222L can also be used as part of a video surveillance system built from multiple cameras via the supplied software D-ViewCam, which supports up to 32 cameras.
A clear picture from different angles
With features pan / tilt and digital zoom IP-camera DCS-5222L provides an overview of a large area from different angles and 4x digital zoom for detail izobrazheniya.1 You can also configure automatic movement of IP-camera DCS-5222L between predetermined positions, which allows patrol a large territory.
Utility mydlink ™ for easy installation and remote viewing on your phone
A convenient utility mydlink ™ can be quickly set up IP-camera DCS-5222L, and then register it on the Web-site mydlink ™. DCS-5222L will automatically configure and connect to the service mydlink ™, which will provide easy access to video over the Web-site mydlink ™. The image from the camera can be viewed even on a smartphone or tablet PC with iOS and Android, so staying in touch constantly.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
