חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת אלחוטית עם תמיכה ב - Full HD ו H.264
EOL EOS
מאפיינים כללים:
Camera Key Features
• 1/2.7-dyuymovy megapixel progressive CMOS-sensor
• The distance of IR illumination: 5 m
• Minimum illumination: 0 lux with IR illumination
• Built-in ICR-filter
• Built-in PIR (Passive Infrared) sensor
• Built-in microphone and speaker
• 10x digital zoom
• Fixed focal length: 4.37 mm
• Aperture F2.0
• Angle of View:
  - Horizontal 67.4 °
  - Vertical 40.8 °
  - Diagonal 75 °
Functional video
• Set the size, quality, frame rate and bit rate image
• Timestamps and paste text
• Windows to configure the motion detection
• 3 customizable private mask
• Customizable shutter speed, brightness, saturation, contrast and sharpness
Video Compression
• Video compression formats H.264/MPEG4/MJPEG
• JPEG for still images
Video Resolution
• 16:9 - 1920x1080 (up to 15 frames per second), 1280x720, 800 x 450 640 x 360, 480 x 270, 320 x 176, 176 x 144 at 30 frames per second
• 4:3 - 1440h1080 (up to 15 frames per second), 1280 x 960, 1024x768, 800 x 600 640 x 480 320 x 240 176 x 144 at 30 frames per second
Audio Support
• G.726
Device Interfaces
• Port Ethernet 10/100 BASE-TX (PoE ports for DCS-2210)
• Wireless interface 802.11n (only for the DCS-2230)
• 1 DI / DO 1
• Slot for Micro SD-Card
Network Protocols
• IPv4, TCP / IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding , RTP / RTSP / RTCP, IP filtering, 3GPP, IGMP, ONVIF
Security
• Protection of the Administrator account and user group
• Password authentication
System requirements for web-based interface
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Netscape, Opera
Event Management
• Motion detection
• PIR-sensor for motion detection
• Event notification and download snapshots / video clips through HTTP, SMPT or FTP
• Support for multiple servers, HTTP, SMPT, FTP
• Multiple Event Notifications
• Several ways to backup
Remote management
• Setting up a web-browser
• Obtaining snapshots / video and save to your hard drive or NAS via web-browser
Support for mobile phones
• Windows 7/Vista/XP, Pocket PC or mobile phone with support for 3GPP
System requirements for the D-ViewCam ™
• Browser: Internet Explorer 6 or above
• Protocol: TCP / IP
Features available in the D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images from 32 cameras on one screen
• Supports all management functions through a web-based interface
• recording options for triggering a sensor or manually
נתונים פיזיים
Power Input
• 5 V DC 1.2 A, 50/60 Hz
Max. power consumption
• 4 W
Operating temperature
• From 0 to 40 ° C
Storage temperature
• -20 To 70 ° C
Humidity
• 20% to 80% (no condensation)
Weight
• 75 g
Certificates
• CE, CE LVD, FCC (Class B), C-Tick
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
