חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת עם תמיכה ב - Full HD ו H.264
EOL EOS
תאור:
24/7 Camera Surveillance
The DCS-2210/2230 Full HD Cube Network Camera is a versatile surveillance solution that is perfect for monitoring low-light environments in your home or small office. It combines a high-resolution 2 Megapixel sensor with a built-in IR LED to help you keep watch over areas in complete darkness. The DCS-2210/2230 also includes a built-in IR cut filter, making it suitable for both day and night applications. Additionally, the DCS-2210/2230 is a complete system with a built-in CPU and web server that transmits high-quality video images for security and surveillance. The DCS‑2210 includes support for Power over Ethernet(PoE), so the camera can be placed in areas where no power outlet is nearby. The DCS-2230 features 802.11n wireless, allowing the camera to be placed anywhere within range of your wireless network. The DCS‑2210/2230 also offers simple installation, an intuitive webbased interface, and remote monitoring and motion detection features for a complete and cost-effective home security solution.
Wireless N Connectivity (DCS-2230)
The DCS-2230 includes 802.11n wireless for fast and easy integration into your existing network environment. Wireless N allows you to stream highquality video to remote sites and mobile devices. A Site Survey feature also allows you to view and connect to nearby wireless networks with ease. The DCS‑2210/2230 also includes a standard Ethernet port for connections to traditional wired networks.
ePTZ For Surveying Regions Of Interest
The ePTZ feature allows users to select a target region for close-up viewing simply by clicking on the video feed displayed within their browser. ePTZ makes use of the camera’s 2 mexapixel resolution to survey a large area effortlessly. Since ePTZ requires no moving parts, there is no need to worry about the camera having mechanical failures.
Easy To Configure And Operate
This network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/Vista/7 to automatically recognize the camera and add it to the network. Sign up with one of the free Dynamic DNS services available on the web to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com), and remotely access the camera without having to remember your IP address. You may also view up to 32 cameras from a central location using the included D-ViewCam software. D-ViewCam has a robust set of features including automated e-mail alerts which can instantly inform administrators of suspicious or unusual activities.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
