חיפוש מהיר
תכונות המוצר:
מצלמת מעקב מגה-פיקסל עם חיישן WDR ואפשרות צילום לילי
EOL EOS
תאור:
Observation of high-resolution
Professional megapixel DCS-3710 sensor with WDR and the possibility of night shooting has a 1/3-inch CMOS-sensor with progressive scan technology, as well as auto iris lens 2.8 ~ 12mm DC. The DCS-3710 enables you to capture video in the absence of light and low light, as well as highlighting the objects behind. In addition, the removable IR cut filter, providing the ability to work in day / night, allows to obtain high-quality video at any time. DCS-3710 is equipped with an interface Power over Ethernet (PoE) and a slot for SD-cards. Because of this, the camera can be easily installed in various locations.
Support for multicast data
DCS-3710 supports multiple video streams of MPEG-4 and MJPEG simultaneously, which provides high image quality and increases the effective bandwidth through compression formats. MJPEG provides file integrity, making it ideal in situations where detailed images of high quality. Data compression is the MPEG-4 allows you to get small files, which is useful for long-term recording, or in networks with low bandwidth. The camera can provide access to video on demand.
Flexible connectivity
DCS-3710 is equipped with inlet and outlet ports for connection to external devices such as IR sensors, switches and alarm relays. The camera is also equipped with RS-485 interface for connecting external devices, pan / tilt. In addition, the interface 12 provides power to the additional LED-light source.
Application wide dynamic range (WDR)
Function WDR (Wide Dynamic Range) provides a clear image even in backlight when the light intensity may change significantly. The DCS-3710 can be successfully applied in environments with high contrast. For example, while inside, the camera DCS-3710 allows you to monitor conditions in the intense sunlight. Thus, the DCS-3710 camera is the ideal solution for security applications.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
