DWL-3600APEOL EOS
נקודת גישה אוניברסלית אלחוטית, בתקן 802.11n עד 300Mbps
תאור
DWL-3600AP - Universal External Access Point 802.11n Wi-Fi, designed for deployment in business class. Flexible in managing and supporting data transfer at high speeds, this Access Point provides easy integration into existing network infrastructure, which can be further expanded. The access point can be made in case a class Plenum (DWL-3600AP/A1A) or plain plastic case (DWL-3600AP/A1A/PC).
High performance
2x2 MIMO technology enables data transmission at speeds up to 300 Mbit/s1 using a frequency of 2.4 GHz. In addition, the access point supports RadioProtect, thanks to which all users will get service with a high level of quality, even when connected to a network of multiple users using legacy devices 802.11b and 802.11g.
Automatic cluster configuration
For small businesses that require multiple access points (APs) and that lack of resources, auto-configuration of the cluster is an ideal solution. When installing a small number of access points DWL-3600AP can perform automatic configuration of the cluster. After completing an administrator configure a single point of access, the same settings will be applied to other access points. Thus, the cluster can combine up to 16 access points.
Unified management
When installing a network using standardized wireless switches can be operated up to 256 access points DWL-3600AP, so the administrator can increase the range of your wireless network.
Security
DWL-3600AP supports the latest security standards including WPA, WPA2, and 802.1X. In addition, DWL-3600AP supports up to 16 virtual access points (VAP), which allows administrators to assign different access rights to user groups. Through the use of standardized wireless D-Link switches can increase the level of security. You can easily detect unauthorized network access point, so the administrator can prevent immediate danger.
Automatic tuning of frequency
If you install multiple access points at a small distance from each other may cause harmful interference. If you find a neighboring node an access point DWL-3600AP can select a channel without interference. This greatly reduces interference and allows the administrator to set access point at a short distance from each other. If the neighbor APs running on the same frequency, DWL-3600AP automatically reduces transmit power. If, for any reason, neighboring APs are no longer valid in the network, DWL-3600AP increases the transmission power to increase the radius of coverage.
Quality of Service
DWL-3600AP supports WMM, so that in case of network congestion, priority will receive time-sensitive traffic. Furthermore, if multiple access points DWL-3600AP are in close proximity to each other, the AP will reject new connection requests, as all resources are used. Instead, the connection request will be passed the next access point. By using this function, no point of access will not be overloaded, while the other neighboring access points are idle.
מאפיינים כללים
System
• Wireless Interface: 802.11b/g/n 2,4 GHz 2x2 MIMO
• Interface LAN: 10/10/100 Gigabit Ethernet
• Antenna: Internal antenna 4
• Antenna Gain: 4,7 dBi
• Supply: IEEE 802.3af Power Over Ethernet or external power adapter
Frequency
• 2.4 GHz - 2.497 GHz
Data transfer rate
• 802.11n:
  6.5 Mbit / s - 130 Mbit / s (20 MHz)
  6.5 MHz - 300 Mbit / s (40 MHz)
• 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11b: 11, 5.5, 2 and 1 Mbit / s
Transmitter output power
• 802.11b:
 21 dBm at 1, 2, 5.5, 11 Mbit / s
• 802.11g:
  21 dBm at 6 Mbit / s ~ 24 Mbit / s
  19 dBm at 36 dBm at Mbit/s18 48 Mbit / s
  17 dBm at 54 Mbit / s
• 802.11n (2,4 GGts/HT-20):
  20 dBm at MCS0 / 8
  20 dBm at MCS1 / 9
  20 dBm at MCS2/10
  20 dBm at MCS3/11
  19 dBm at MCS4/12
  18 dBm at MCS5/13
  17 dBm at MCS6/14
  16 dBm at MCS7/15
• 802.11n (2,4 GGts/HT-40)
  19 dBm at MCS0 / 8
  19 dBm at MCS1 / 9
  19 dBm at MCS2/10
  19 dBm at MCS3/11
  17 dBm at MCS4/12
  16 dBm at MCS5/13
  14 dBm at MCS6/14
  14 dBm at MCS7/15
Receiver Sensitivity
• 802.11b:
  -89 DBm at 2 Mbit / s
  -84 DBm at 11 Mbit / s
• 802.11g:
  -85 DBm at 6 Mbit / s
  -84 DBm at 9 Mbit / s
  -84 DBm at 12 Mbit / s
  -82 DBm at 18 Mbit / s
  -78 DBm at 24 Mbit / s
  -73 DBm at 36 Mbit / s
  -70 DBm at 48 Mbit / s
  -68 DBm at 54 Mbit / s
  - 82dBm at MCS0 / 8
  - 79dBm at MCS1 / 9
  - 77dBm at MCS2/10
  - 74dBm at MCS3/11
  - 70dBm at MCS4/12
  - 66dBm at MCS5/13
  - 65dBm at MCS6/14
  - 64dBm at MCS7/15
  -79 DBm at MCS0 / 8
  -76 DBm at MCS1 / 9
  -74 DBm at MCS2/10
  -71 DBm at MCS3/11
  -67 DBm at MCS4/12
  -63 DBm at MCS5/13
  -62 DBm at MCS6/14
  -61 DBm at MCS7/15
Security
• SSID: 16 SSID, Station Isolation
• Safety:
  + WEP
  + Dynamic WEP
  + WPA Personal / Enterprise
  + WPA2 Personal / Enterprise
• Detection and Prevention:
  + Classification of unauthorized access points and unauthorized
• Authentication:
  + Filtering by MAC-addresses
  + 802.1x
System control
• Web-User Interface: HTTP / HTTPS
• Command line: SNMP, SSH, Telnet
תקנים
הורדות
איורים
DWL-3600AP/Ax
מראה מקדימה
מראה משמאל
מראה מאחורה
דף מידע
ראה גם
