DWL-3600AP - Universal External Access Point 802.11n Wi-Fi, designed for deployment in business class. Flexible in managing and supporting data transfer at high speeds, this Access Point provides easy integration into existing network infrastructure, which can be further expanded. The access point can be made in case a class Plenum (DWL-3600AP/A1A) or plain plastic case (DWL-3600AP/A1A/PC).
High performance
2x2 MIMO technology enables data transmission at speeds up to 300 Mbit/s1 using a frequency of 2.4 GHz. In addition, the access point supports RadioProtect, thanks to which all users will get service with a high level of quality, even when connected to a network of multiple users using legacy devices 802.11b and 802.11g.
Automatic cluster configuration
For small businesses that require multiple access points (APs) and that lack of resources, auto-configuration of the cluster is an ideal solution. When installing a small number of access points DWL-3600AP can perform automatic configuration of the cluster. After completing an administrator configure a single point of access, the same settings will be applied to other access points. Thus, the cluster can combine up to 16 access points.
Unified management
When installing a network using standardized wireless switches can be operated up to 256 access points DWL-3600AP, so the administrator can increase the range of your wireless network.
Security
DWL-3600AP supports the latest security standards including WPA, WPA2, and 802.1X. In addition, DWL-3600AP supports up to 16 virtual access points (VAP), which allows administrators to assign different access rights to user groups. Through the use of standardized wireless D-Link switches can increase the level of security. You can easily detect unauthorized network access point, so the administrator can prevent immediate danger.
Automatic tuning of frequency
If you install multiple access points at a small distance from each other may cause harmful interference. If you find a neighboring node an access point DWL-3600AP can select a channel without interference. This greatly reduces interference and allows the administrator to set access point at a short distance from each other. If the neighbor APs running on the same frequency, DWL-3600AP automatically reduces transmit power. If, for any reason, neighboring APs are no longer valid in the network, DWL-3600AP increases the transmission power to increase the radius of coverage.
Quality of Service
DWL-3600AP supports WMM, so that in case of network congestion, priority will receive time-sensitive traffic. Furthermore, if multiple access points DWL-3600AP are in close proximity to each other, the AP will reject new connection requests, as all resources are used. Instead, the connection request will be passed the next access point. By using this function, no point of access will not be overloaded, while the other neighboring access points are idle.
