DKVM-IP1מיועד לפרויקטים
מתג KVM על גבי IP כולל יציאת קונסול ו/או ניהול WEB +כבל KVM
היכן לקנות
תאור
The D-Link DKVM-IP1 KVM Switch over IP provides remote KVM access via a LAN, a WAN, or an Internet connection to a server.
Designed for server control with VGA, PS/2 and USB support, this KVM over IP appliance integrates KVM, Ethernet interface and external modem support in a one-box solution. Control of Single or Multiple Servers. The DKVM-IP1 provides secure high-performing KVM Over IP technology with a direct connection to the back of your server.
This KVM switch can also be connected to a multi-port KVM switch for control of multiple servers.Remote Connection. The DKVM-IP1 contains a default IP address, which can be easily changed to another IP address used by your network. From a remote site, your IT administrator can key in the IP address of the DKVM-IP1 from a web browser to connect to it and start control a remote server. This type of remote control can help eliminate on-site maintenance costs and service calls, and avoids for you emergency phone calls from your remote data centers.
In addition to troubleshooting, this KVM switch can also let an IT administrator upgrade or configure a PC system from the Internet.
Another application of this KVM switch is remote mass storage control.Security. The DKVM-IP provides SSL (up to 256-bit) encryption protocol to prevent security breaches.Device Interfaces.
 The DKVM-IP1 switch includes one interface to a server, which includes a video connection, a PS/2 keyboard connection, a PS/2 mouse connection, and a USB 2.0 connection. To the console side, it has a video port, a PS/2 mouse port and a PS/2 keyboard port.
Remote site connection is through a 10/100BASE-TX Ethernet port, which can be connected to a LAN or to a remote router. External modem support is available through an RS-232 COM port, in case your network is down.
מאפיינים כללים
Network / modem interface
• RJ-45 10/100BASE-TX Ethernet
• RS-232 DB-9
Console connectors
• Connector 1 mini Din 6-pin connectors for keyboard
• Connector 1 mini Din 6-pin to connect the mouse
• Slot 1 HDDB 15 pin for connection of the monitor
Connectors for the computer or KVM Switches
USB
• USB 2.0 port type B
Reset button
Indicator lights
• Channel / speed
• activity
Video resolution
• Locally: 1600 x 1200
• Remotely: 1280 x 1024
נתונים פיזיים
Power
• Through the power adapter 5V DC 2.5A
Operating temperature
• From 0 º to 50 º C
Storage temperature
• From -20 º to 60 º C
Humidity
• From 0 to 80%, noncondensing
Electromagnetic compatibility
• FCC Class A
• CE
• C-Tick
Size
• 167 x 141 x 27 mm
Weight
• 670 g
תקנים
הורדות
איורים
DKVM-IP1/Bx
מראה מקדימה
מראה מימין
מראה מאחורה
מראה מאחורה
דף מידע
ראה גם
