DES-1008PEOL EOS
מתג שולחני 8 פורטים 10/100Mbps PoE
תאור
Main Features
Up To 56 Watts Of PoE
Connect More High-Powered IP Cameras, IP Phones & Wireless Access Points
Transmit Power & Data Through One Cable Using 802.3af PoE Standard
Quick, Simple Plug & Play Installation
The D-Link 8-Port Desktop Switch with 4 PoE Ports (DES-1008P) enables both home and office users to easily connect and supply power to Power over Ethenet (PoE) devices such as wireless Access Points (APs), IP cameras, and IP phones while adding more Ethernet devices like computers, printers, and Network Attached Storage (NAS) onto a network. Built with home and small business users in mind, this compact PoE switch operates quietly, making it ideal for use in virtually any room or office.
POWER OVER ETHERNET IEEE 802.3af
The DES-1008P features 4 10/100BASE-TX ports that support the IEEE 802.3af PoE protocol. Each of the 4 PoE ports can supply up to 15.4 Watts, a total PoE budget of 56 Watts, allowing users to attach an IEEE 802.3af compliant device to the DES-1008P without requiring additional power. This eliminates the need of having to place networking devices within close proximity of a power outlet and minimizes cable clutter in awkward places such as ceilings or walls. For devices that are not 802.3af compliant, a PoE adapter, such as D-Link’s DWL-P50 can be used to enable the non-compliant device to receive power through the DES-1008P.
SUPERIOR PERFORMANCE
No configuration is required and installation is quick and easy. Support for Auto-MDI/MDI-X on all ports eliminates the need for crossover cables for connection to another switch or hub. Auto-Negotiation on each port senses the link speed of a network device (either 10 or 100) and intelligently adjusts for compatibility and optimal performance. When an IEEE 802.3af compliant device is attached, power supplied to that device will be automatically adjusted to fit the device. The DES-1008P also features diagnostic LEDs, which display status and activity, allowing you to quickly detect and correct problems on the network. With wire-speed filtering and store-and-forward switching, the DES-1008P also maximizes network performance while minimizing the transmission of bad network packets.
Combining the convenience of PoE, superior performance, and ease of use, the D-Link 8-Port Desktop Switch with 4 PoE Ports (DES-1008P) is the ideal choice for adding PoE device to both a home or small business network.
WHAT THIS PRODUCT DOES
The D-Link DES-1008P is an 8-Port 10/100Mbps PoE Ethernet Switch with four PoE Ports that can provide power to PoE-enabled devices such as wireless Access Points (APs), IP phones, and IP cameras. You can also add other Ethernet devices like computers, printers, and Network Attached Storage (NAS) onto your network. This device runs ultra-quiet, making it ideal for both home and small office use.
HASSLE-FREE SETUP
The DES-1008P is a plug-and-play device requiring no configuration, which makes setup simple and hassle-free. Connect multiple computers and share files, music, and video across your home or small office network, or create a multi-player gaming environment. If you need help setting up your device, visit D-Link’s award-winning customer support web site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
מאפיינים כללים
תקנים
  • IEEE 802.3 Ethernet/IEEE 802.3u Fast Ethernet
  • ניהול תעבורה 802.3x
  • IEEE 802.3af Power over Ethernet
ממשק
  • 4 פורטים 10/100 עם תמיכת PoE
  • 4 פורטים 10/100 בלי תמיכת PoE
ביצועים
  • טבלת כתובות MAC : 1K
  • אופן מיתוג: Store-and-forward
תקנים
הורדות
איורים
DES-1008P/A
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
