חיפוש מהיר
תכונות המוצר:
מתג מנוהל עם 44 פורטים במהירות ג'יגהביט, ארבע יציאות משולבות ג'יגהביט/אופטי (SFP) ושתי יציאות 10GBase-CX4 ותמיכה ב - PoE
מאפיינים כללים:
Interfaces
• 44 port 10/100/1000Base-T
• 4 Combo 10/100/1000Base-T / SFP
• 2-port 10G c CX4 connector
Redundant Power Supply
• DPS-700
Console port
• RJ-45
Slot for SD-cards
• 1
Indicators
• Power (per device)
• Console (per device)
• RPS (per device)
• Master (device)
• Fan (per device)
• SD (per device)
• PoE (per device)
• Link / Activity (per port)
Performance
• Switching matrix 136 Gbit / s
Speed ​​packet forwarding
• 101,19 Mpps
Packet Buffer
• 2MB
Flash-memory
• 32 MB
PoE
• 802.3af PoE standards and 802.3at
PoE power budget
• 370W
• 760 W (DPS-700)
Features 2 levels
• MAC-address table: 16K entries
• Flow Control
  • 802.3x Flow Control
  • HOL Blocking Prevention
• Jumbo-frame up to 13 Kbytes
• 802.3ad Link Aggregation
  • Max. 32 device group, 8 gigabit ports per group
• Spanning Tree Protocols
  • 802.1D STP
  • 802.1w RSTP
  • 802.1s MSTP
  • BPDU Filtering
  • Root Restriction
• Loopback Detection is
• Ethernet Ring Protection Switching (ERPS)
• Port Mirroring
  • One-to-One
  • Many-to-One
  • On the basis of the flow
  • RSPAN
Multicast Layer 2
• IGMP Snooping
  • IGMP v1 / v2 / v3 Snooping
  • 1024 IGMP-support groups
  • Fast Leave port-based / node
• Limit multicast on IP-addresses
  • Up to 24 profiles filtering IGMP, 32 address range to profile
• MLD Snooping
  • MLD v1 / v2 Snooping
  • Supports up to 1024 groups
  • Fast Leave-based site
VLAN
• VLAN Group
  • Max. 4K VLAN-group
• GVRP
  • Max. 4K dynamic VLAN-group
• 802.1Q Tagged VLAN
• VLAN-based port
• 802.1v Protocol VLAN
• Voice VLAN
• VLAN MAC-based address
• Double VLAN (Q-in-Q)
  • Port-based Q-in-Q
• ISM VLAN
• Asymmetric VLAN
• Private VLAN
• VLAN Trunking
Quality of service (QoS)
• 802.1p
• 8 queues per port
• Mechanisms queuing
  • Strict Priority
  • Weighted Round Robin (WRR)
  • Strict + WRR
• Support for the following streams
  • Tagging 802.1p priority
  • Priority Tagging TOS / DSCP
  • Bandwidth Management
• CoS-based
  • The switch port
  • VLAN ID
  • 802.1p Priority Queues
  • MAC-address
  • IPv4-address
  • DSCP
  • the type of protocol
  • TCP / UDP-port
  • The contents of the package, user-defined
  • IPv6 address-
  • Class IPv6-traffic
  • IPv6 flow label
  • Based on the port (incoming / outgoing, min. Step up to 8 kbit / s)
  • On the basis of the flow (incoming / outgoing, min. Step up to 8 kbit / s)
• Three-color marking
  • CIR / PIR min. Step 8 kbit / s
  • Two Rate Three Color Marker (trTCM), CBS / PBS
  • Single Rate Three Color Marker (srTCM), CBS / EBS
Access Control Lists (ACL)
• ACL based on:
  • 802.1p Priority
  • VLAN ID
  • MAC-address
  • Ether Type
  • IPv4-address
  • DSCP
  • Non-TCP / UDP-port
  • IPv6 address-
  • IPv6 flow label
• Support for up to 1,5K access rules
• ACL based on time
• CPU Interface Filtering
Security
• SSH v2
• SSL v1 / v2 / v3
• Port Security
  • Up to 64 MAC-addresses per port / VLAN
• Linking IP-MAC-Port
  • Checking the ARP-packets
  • Check the IP-packet
  • DHCP Snooping
  • IPv6 ND Snooping
  • Up to 510 entries per device
• Protection from the broadcast / multicast / unicast storm
• Traffic Segmentation
• D-Link Safeguard Engine
• Filtering NetBIOS / NetBEUI
• DHCP Server Screening
• Prevention of ARP Spoofing Attacks
• Prevention of DoS attacks
• Protection against attacks BPDU
AAA
• 802.1X:
  • Access control based on port
  • Based Access Control Node
  • Policy Identity-driven (VLAN, ACL or QoS)
  • Authentication Database Failover
• Access control based on Web (WAC):
• Access Control MAC-based (MAC):
• Access control based on the Japanese Web-based interface
• Guest VLAN
• Microsoft® NAP
  • Support for 802.1X NAP
  • Support for DHCP NAP
• RADIUS Accounting
• TACACS + Accounting
• RADIUS and TACACS authentication for access to the switch
• Accounts with 4 levels of access rights
• Compound Authentication
Features 3 levels
• The maximum number of IP-interface - 16
• ARP Proxy
• VRRP
• IPv6 Neighbour Discovery (ND)
• IPv6 transition
Routing Level 3
• Static Routing
  • Up to 512 entries static routing for IPv4 / IPv6
• RIP
• OSPF
• IP Directed Broadcast
Multicast Layer 3
• IGMP
• MLD
• IGMP / MLD Proxy
• Multicast Duplication
• PIM DM
• PIM SM
• PIM SSM
• PIM Spare-Dense Mode
• DVMRPv3
Features D-Link Green
• RoHS compliant
• Reduction of energy consumption based on the connection status
• Reduce energy consumption depending on the length of the cable
• PoE on schedule
• IEEE 802.3az Energy Efficient Ethernet (EEE)
OAM
• Diagnostic cable
• 802.3ah Ethernet Link OAM
• 802.3ah D-Link Extension: D-link Unidirectional Link Detection (DULD)
• ITU-T Y.1731
Office
• Web-interface
• Command Line Interface (CLI)
• Telnet-server
• Telnet-client
• TFTP-client
• ZModem
• SNMP v1 / v2c / v3
• SNMP Traps
• System Log
• RMON v1:
  • Support groups 1,2,3,9
• RMON v2:
  • Support group ProbeConfig
• LLDP
• BootP / DHCP-Client
• Auto Configuration via DHCP
• DHCP Relay
• DHCP Client Option 12
• DHCP Relay Option 18, 37, 82
• Flash File System
• Support for multiple versions of software
• Support for multiple versions of configurations
• CPU Monitoring
• Use the debug (Debug Command)
• SNTP
• Restoration of the password
• Encryption password
• Trusted Host
• Microsoft® NLB
• ICMPv6
• sFlow
• Add a label PPPoE Circuit-ID
MIB
• RFC 1213 MIB II
• RFC 4188 Bridge MIB
• RFC 1157, 2571-2576 SNMP MIB
• RFC 1907 SNMPv2 MIB
• RFC 1757 RMON MIB 2819
• RFC 2021 RMONv2 MIB
• RFC 1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC 2674 802.1p MIB
• RFC 2233, 2863 IF MIB
• RFC 2925 PING and TRACEROUTE MIB
• RFC 2674, 4363 802.1p MIB
• RFC 1065, 1066, 1155, 1156, 2578 MIB Structure
• RFC1157, 2571-2576 SNMP MIB
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC4293 IPv6 SNMP Mgmt Interface MIB
• RFC 2737 Entity MIB (version 2)
Compliance with RFC standards
• RFC 768 UDP
• RFC 791 IP
• RFC 792, 2463, 4443 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 3513, 4291, IPv6 Addressing Architecture
• RFC 2893, 4213 IPv4 / IPv6 dual stack function
• RFC 2463, 4443 ICMPv6
• RFC 2462, 4862 IPv6 Stateless Address Auto Configuration
• RFC 2464 IPv6 Ethernet and definition
• RFC 1981 Path MTU Discovery for IPv6
• RFC 2460 IPv6
• RFC 2461, 4861 Neighbor Discovery for IPv6
• RFC 783 TFTP
• RFC 2068 HTTP
• RFC 1492 TACACS
• RFC 2866 RADIUS Accounting
• RFC 2474, 3260 DiffServ
• RFC 1321, 2284, 2865, 3580, 3748
Extensible Authentication Protocol (EAP)
• RFC 2571, 2572, 2573, 2574, SNMP
• IPv6 Ready Logo Phase 2
• RFC 854 Telnet
• RFC 951, 1542 BootP
נתונים פיזיים
Dimensions
• 440 x 380 x 44 mm
Weight
• 6420 g
Input supply
• 100 to 240 VAC, 50 Hz ~ 60
Max. power consumption
• 539 watts (370W load PoE)
• 963 watts (760 watts at startup PoE)
Thermal
• 1838 BTU / hr (370 watts at startup PoE)
• 3283,83 BTU / hr (760 watts at startup PoE)
MTBF (hours)
• 213,575
The noise level
• Max .: 50.2 dB; min .: 37.3 dB
Ventilation system
• Smart Fan1 (> 40 ° C: high rate of <35 °: low speed)
Temperature
• Operating: 0 to 50 ° C
• Storage: -40 to 70 ° C
Humidity
• Storage: 5% to 90% non-condensing
EMI
• FCC Class A
• CE Class A
• VCCI Class A
• IC
• C-Tick
• BSMI
Security
• CB
• cUL
• LVD
• BSMI
Certificates
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
