DES-1018MPמיועד לפרויקטים
מתג שולחני עם 16 פורטים במהירות 10/100Mbps עם שתי יציאות משולבות ג'יגהביט/אוטפי (SFP) עם תמיכה ב PoE ותכונת חיסכון בחשמל (מארז מתכת)
היכן לקנות
תאור
Unmanaged Switch DES-1018P / DES-1018MP with 18 ports and support for PoE, allowing users to easily connect and supply power to PoE-compatible various devices such as wireless access points, network cameras and IP-telephony. DES-1018P / DES-1018MP can be used to connect other Ethernet-devices, including computers, printers, and network drives.
Supports IEEE 802.3af PoE
In DES-1018P / DES-1018MP provides 8 or 16 ports with support for IEEE 802.3af PoE. Each PoE-port provides power up to 15.4W with a total budget of 80 W (DES-1018P) or 246.4 W (DES-1018MP), which allows users to connect to the DES-1018P / 1018MP any device compatible with the IEEE 802.3 standard af. With support for PoE technology can reduce the cost of additional summing the power cord or place any network equipment in remote places, regardless of the location of electrical outlets.
The possibility of expanding the network
The presence of two Gigabit combo ports trunk can increase network capacity and provide fault-tolerant wire connection required for reliable data transmission, video surveillance and traffic voice applications. Such hardware solution helps to increase bandwidth through the use of high-speed gigabit connectivity based on fiber-optic communication line or twisted pair.
Energy efficient
Implemented in the DES-1018P / DES-1018MP support energy efficiency standards IEEE 802.3az will reduce operating costs. With this switch determines the functional status of the connection and automatically cuts off power ports that are idle. In addition, the switch support JavaScript Smart Fan, the application of which automatically adjusts the fan speed, which helps to reduce energy consumption and noise reduction. *
Easy to install
DES-1018P / DES-1018MP relates to devices Plug-and-Play and requires no configuration. Simply connect the switch to the network, and then connect it to your computer, then you can share files and make VoIP-calls. Support auto polarity MDI / MDIX on all ports eliminates the need for crossover cables when connecting to another switch or hub. Auto-negotiation on each port to determine the speed of connection to a network device (10 or 100 Mbit / s) and perform an smart setting for optimum compatibility and performance. Combining the advantages of using technology PoE, high data rates, reliability and ease of installation, this unmanaged switch with 18 ports is an excellent choice for connecting PoE-compliant devices to the network.
מאפיינים כללים
Interfaces
• 16-port 10 / 100BASE-TX PoE-enabled
• 2 combo port 10/100 / 1000BASE-T / SFP
Standards
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3z
• IEEE 802.3x Flow Control
Switching matrix
• 7.2 Gbit / s
Speed forwarding 64-byte packets
• 5.36 Mbit / s
Transmission Method
• Store-and-forward
MAC-address table
• 8K
Packet buffer
• 384 KB
Advanced features interface
• Automatic detection of polarity MDI / MDIX on all ports
Indicators
• On the device: Power
• In Port: Link / Act and Speed
• On the PoE-port: Power fail, Power OK
Fan
• 1 fan with support for the Smart Fan
PoE standard
• IEEE 802.3af
PoE-ports
• Ports 1-16, up to 15.4 watts per port
PoE power budget
• 246.4 W
ESD protection
up to 2 kV for ports 1-16
נתונים פיזיים
Dimensions
• 280 x 210 x 44 mm
Weight
• 2.15 kg
Power
• Power Input: 100-240 VAC, 50-60 Hz
Power consumption
• Max. power consumption: 301.6 W (PoE enabled), 15.6 W (PoE off)
• Power consumption in standby mode: 9.3 W / 100 V; 10.5 W / 240
Temperature
• Operating: 0º to 40ºC
• Storage: -40º to 70ºC
Humidity
• Operating: 0% to 95% (non-condensing)
• Storage: 0% to 95% (non-condensing)
MTBF (hours)
• 361,802 hours
Heat release
• 1029,5 BTU / hr
Certifications
• FCC Class A
• CE
• CCC
• RoHS
• VCCI
• BSMI
• C-Tick
Security
• CB
• cUL
• LVD
• CCC
• BSMI
תקנים
הורדות
איורים
DES-1018MP/A
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
