DGS-1005D/H2EOL EOS
תאור
Gigabit data rate on the network
Gigabit Switch 5-port D-Link DGS-1005D provides data transfer and work online gaming at speeds up to 2000 Mb / s. Indicators of two colors for each port to help you easily determine the status of the connection. DGS-1005D supports QoS, prioritization provides delay sensitive traffic and important for efficient transmission of multimedia data in real-time, high-quality VoIP calls and online gaming.
Realization of technology D-Link Green
Switch DGS-1005D which supports plug-and-play is a device that uses D-Link Green, provides energy conservation, low heat dissipation and longer product life without sacrificing performance or functionality. Switch support JavaScript IEEE 802.3az Energy-Efficient Ethernet (EEE), by which it is determined when the connected computer is turned off or when there is no Ethernet-traffic on and off power to the inactive ports, thus saving a considerable amount of energy. In addition, the switch is able to adjust the power consumption by determining the length of the cable connected to the port. Both of these features work together to automatically save energy.
Caring for the environment
5-Port Gigabit Switch DGS-1005D is designed to meet the requirements of environmental protection, in accordance with the standard EnergyStar Level V and regulations CEC and MEPS, requires the use of power adapters that reduce energy consumption. The switch also complies with RoHS standards to limit the use of hazardous substances and uses recyclable packaging, which significantly reduces the amount of waste in accordance with Directive WEEE.
מאפיינים כללים
General
• Built-in D-Link Green
• Inexpensive Gigabit solution for home networks and SOHO
• 5-port 10/100/1000 Mbit / s Gigabit
• Switching Matrix: 10 Gbit / s
• Auto MDI / MDIX on all ports
• Transmission Method: Store-and-forward
• Ethernet / Fast Ethernet: Full duplex / half duplex
• IEEE 802.3x Flow Control
• Jumbo-frames 9216 bytes
• Supports IEEE 802.1p QoS (4 queues, Strict Mode)
• Supports Cable Diagnostics
• RoHS compliant
• Plug-and-play
• Passive cooling system
Standards
• IEEE 802.3 10BASE-T Ethernet (copper twisted pair)
• IEEE 802.3u 100BASE-TX Fast Ethernet (copper twisted pair)
• IEEE 802.3ab 1000BASE-TX Gigabit Ethernet (copper twisted pair)
• ANSI / IEEE 802.3 NWay auto-negotiation and mode of operation
• Flow Control IEEE 802.3h
• IEEE 802.1p QoS
Protocol
• CSMA / CD
Data rate
• Ethernet:
• 10 Mbit / s (half duplex)
• 20 Mbit / s (full duplex)
• Fast Ethernet:
• 100 Mbit / s (half duplex)
• 200 Mbit / s (full duplex)
• Gigabit Ethernet:
• 2000 Mbit / s (full duplex)
Topology
• Star
Network Cables
• 10BASE-T:
• UTP Cat. 3/4/5 / 5e (100m max.)
• EIA / TIA-586 100 Ohm STP (100m max.)
• 100BASE-TX, 1000BASE-T:
• UTP Cat. 5 / 5e (100m max.)
Interfaces transmission medium
• Automatic detection of MDI / MDIX on all ports
Indicators
• In Port: Link / Activity / Speed
• On the device: Power
Transmission Method
• Store-and-Forward
MAC-address table
• 2K entries per device
Study of MAC-addresses
• Auto update
Filtration rate / packet
• Ethernet: 14,880 packets per second. the port
• Fast Ethernet: 148,800 packets per second. the port
• Gigabit Ethernet: 1488000 packets per second. the port
Packet buffer
• 128 Kbytes per device
