DIR-620SEOL EOS
Wireless N300 Router with 3G/LTE Support and USB Port
Kirjeldus
USB Port
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
In order to use the multifunction USB port effectively, the router supports simultaneous operation of several USB devices. For example, you can access multimedia content of the connected HDD storage and at the same time share a USB printer1.
Wireless Interface
Using the DIR-620S device, you are able to quickly create a wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-620S includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
In addition, the router supports IPsec and allows to create secure VPN tunnels.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-620S via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
The configuration wizard allows you to quickly switch DIR-620S to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
Põhiomadused
				 Hardware
				 Processor
				 • RTL8196D (620MHz)
				 RAM
				 • 64MB, DDR SDRAM
				 Flash
				 • 8MB, SPI
				 Interfaces
				 • 10/100BASE-TX WAN port
				• 4 10/100BASE-TX LAN ports
				• USB 2.0 port
				 LEDs
				 • POWER
				• WLAN
				• WPS
				• INTERNET
				• 4 LAN LEDs
				• USB
				 Buttons
				 • ON/OFF button to power on/power off
				• RESET button to restore factory default settings
				• WPS button to set up wireless connection and enable/disable wireless network
				 Antenna
				 • Two external non-detachable antennas 5dBi gain
				 MIMO
				 • 2 x 2
				 Power connector
				 • Power input connector (DC)
				 Software
				 WAN connection types
				 • LTE
				• 3G
				• PPPoE
				• IPv6 PPPoE
				• PPPoE Dual Stack
				• Static IPv4 / Dynamic IPv4
				• Static IPv6 / Dynamic IPv6
				• PPPoE + Static IP (PPPoE Dual Access)
				• PPPoE + Dynamic IP (PPPoE Dual Access)
				• PPTP/L2TP + Static IP
				• PPTP/L2TP + Dynamic IP
				 Network functions
				 • Support of IEEE 802.1X for Internet connection
				• DHCP server/relay
				• Advanced configuration of built-in DHCP server
				• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
				• Automatic obtainment of LAN IP address (for access point/repeater/client modes)
				• DNS relay
				• Dynamic DNS
				• Static IP routing
				• Static IPv6 routing
				• IGMP Proxy
				• RIP
				• Support of UPnP IGD
				• Support of VLAN
				• WAN ping respond
				• Support of SIP ALG
				• Support of RTSP
				• WAN reservation
				• Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
				• Setup of maximum TX rate for each port of the router
				• Built-in UDPXY application
				• XUPNPD plug-in
				 Firewall functions
				• IP filter
				• IPv6 filter
				• MAC filter
				• URL filter
				• DMZ
				• Prevention of ARP and DDoS attacks
				• Virtual servers
				• Built-in Yandex.DNS web content filtering service
				 VPN
				• IPsec tunnels
				  - IKEv1 support
					  - DES encryption
					  - NAT Traversal
					  - Support of DPD (Keep-alive for VPN tunnels)
				 USB interface functions
				 • USB modem
				   Auto connection to available type of supported network (4G/3G/2G)
				   Auto configuration of connection upon plugging in USB modem
				   Enabling/disabling PIN code check, changing PIN code1
				• USB storage
				   File browser
				   Print server
				   Access to storage via accounts
				   Built-in Samba/FTP/DLNA server
				   Built-in Transmission torrent client; uploading/downloading files from/to USB storage
				 Management and monitoring
				 • Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
				• Bilingual web-based interface for configuration and management (Russian/English)
				• Support of logging to remote host/connected USB storage
				• Ping utility
				• Traceroute utility
				• TR-069 client
				• Automatic reboot on schedule
				 Wireless Module Parameters
				 Standards
				 • IEEE 802.11b/g/n
				 Frequency range
				The frequency range depends upon the radio frequency regulations applied in your country
				 • 2400 ~ 2483.5MHz
				 Wireless connection security
				 • WEP
				• МАС filter
				• WPS (PBC/PIN)
				 Advanced functions
				 • Support of client mode
				• WMM (Wi-Fi QoS)
				• Information on connected Wi-Fi clients
				• Advanced settings
				• Smart adjustment of Wi-Fi clients
				• Guest Wi-Fi / support of MBSSID
				• Rate limitation for wireless network/separate MAC addresses
				• Periodic scan of channels, automatic switch to least loaded channel
				• Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
				 Wireless connection rate
				 • IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11n : from 6.5 to 300Mbps (from MCS0 to MCS15)
				 Transmitter output power
				 • 802.11b (typical at room temperature 25 °C)
				   15dBm at 1, 2, 5.5, 11Mbps
				• 802.11g (typical at room temperature 25 °C)
				   15dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps
				• 802.11n (typical at room temperature 25 °C)
				   HT20/HT40
				   15dBm at MCS0/1/2/3/4/5/6/8/9/10/11/12/13/14
				   14dBm at MCS0/7
				 Receiver sensitivity
				 • 802.11b (typical at PER = 8% at room temperature 25 °C)
				   -82dBm at 1Mbps
				   -80dBm at 2Mbps
				   -78dBm at 5.5Mbps
				   -76dBm at 11Mbps
				• 802.11g (typical at PER = 10% at room temperature 25 °C)
				   -85dBm at 6Mbps
				   -84dBm at 9Mbps
				   -82dBm at 12Mbps
				   -80dBm at 18Mbps
				   -77dBm at 24Mbps
				   -73dBm at 36Mbps
				   -69dBm at 48Mbps
				   -68dBm at 54Mbps
				• 802.11n (typical at PER = 10% at room temperature 25 °C)
				   HT20
				   -82dBm at MCS0/8
				   -79dBm at MCS1/9
				   -77dBm at MCS2/10
				   -74dBm at MCS3/11
				   -70dBm at MCS4/12
				   -66dBm at MCS5/13
				   -65dBm at MCS6/14
				   -64dBm at MCS7/15
				   HT40
				   -79dBm at MCS0/8
				   -76dBm at MCS1/9
				   -74dBm at MCS2/10
				   -71dBm at MCS3/11
				   -67dBm at MCS4/12
				   -63dBm at MCS5/13
				   -62dBm at MCS6/14
				   -61dBm at MCS7/15
				 Modulation schemes
				• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
				• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
				 Physical Parameters
				 Dimensions (L x W x H)
				 • 174 x 115 x 30 mm (6.85 x 4.53 x 1.18 in)
				 Weight
				 • 227 g (0.5 lb)
				 Operating Environment
				 Power
				 • Output: 12V DC, 1A
				 Temperature
				 • Operating: from 0 to 40 °C
				• Storage: from -20 to 65 °C
				 Humidity
				 • Operating: from 10% to 90% (non-condensing)
				• Storage: from 5% to 95% (non-condensing)
				 Delivery Package
				 • Router DIR-620S
				• Power adapter DC 12V/1A
				• Ethernet cable (CAT 5)
				 Supported USB modems2
				 GSM
				 • Alcatel X500
				• D-Link DWM-152C1
				• D-Link DWM-156A6
				• D-Link DWM-156A7
				• D-Link DWM 156A8
				• D-Link DWM-156C1
				• D-Link DWM-157B1
				• D-Link DWM-157B1 (Velcom)
				• D-Link DWM-158D1
				• D-Link DWR-710
				• Huawei E150
				• Huawei E1550
				• Huawei E156G
				• Huawei E160G
				• Huawei E169G
				• Huawei E171
				• Huawei E173 (Megafon)
				• Huawei E220
				• Huawei E3131 (MTS 420S)
				• Huawei E352 (Megafon)
				• Huawei E3531
				• Prolink PHS600
				• Prolink PHS901
				• ZTE MF112
				• ZTE MF192
				• ZTE MF626
				• ZTE MF627
				• ZTE MF652
				• ZTE MF667
				• ZTE MF668
				• ZTE MF752
				 LTE
				 • Alcatel IK40V
				• D-Link DWM-222
				• Huawei E3131
				• Huawei E3272
				• Huawei E3351
				• Huawei E3372s
					• Huawei E3372h-153
					• Huawei E3372h-320
				• Huawei E367
				• Huawei E392
				• Megafon M100-1
				• Megafon M100-2
				• Megafon M100-3
				• Megafon M100-4
				• Megafon M150-1
				• Megafon M150-2
				• Quanta 1K6E (Beeline 1K6E)
				• MTS 824F
				• MTS 827F
				• Yota LU-150
				• Yota WLTUBA-107
				• ZTE MF823
				• ZTE MF823D
				• ZTE MF827
				• ZTE MF833T
					• ZTE MF833V
				 Smartphones in USB tethering mode
				 • Some models of Android smartphones
1For some models of USB modems.
2The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Sertifikaadid
Sidustooted
DIR-620S   Wireless N300 Router with 3G/LTE Support and USB Port
