DFE-520TXEOL
Fast Ethernet PCI Network Adapter
Kirjeldus
D-Link DFE-520TX Fast Ethernet PCI Network Adapter is a high-performance, cost-efficient, auto-sensing 10/100 Mbps dual-speed PCI adapter. It can be installed in any PC equipped with a PCI expansion slot. This card makes extensive use of the single-chip technology and is equipped with an on-board FIFO buffer, providing your computer with a fast, reliable connection to an Ethernet network.
Powerful Performance
The DFE-520TX operates in the 32-bit Bus Master mode, delivering throughputs of multiple megabits per second, with little stress on the host CPU. The module transfers data directly to and from the host memory, bypassing bottlenecks in the system and alleviating the CPU workload. This allows your computer to concentrate on the application at hand, instead of the network operation task.
Versatile Functionality
The DFE-520TX single connector connects to either 10BASE-T Ethernet or 100Base-TX Fast Ethernet without the need for any configuration. It automatically detects and negotiates the highest available speed and duplex mode with the connected device for both 10Base-T and 100Base-TX modes.
Põhiomadused
Device Interfaces
• One 10/100Base-TX port
Standards
• IEEE 802.3i 10Base-T
• IEEE 802.3u 100Base-TX
• ANSI/IEEE 802.3 NWay auto-negotiation
• PCI local bus 2.3 specifications
Protocol
• CSMA/CD
Data Transfer Rates
• Ethernet: 10 Mbps (half-duplex) / 20 Mbps (full-duplex)
• Fast Ethernet: 100 Mbps (half-duplex) / 200 Mbps (full-duplex)
Supported Drivers
• Microsoft Windows 10 32/64-bit InBox driver (built into the OS)
• Microsoft Windows 8.1 32/64-bit
• Microsoft Windows 8 32/64-bit
• Microsoft Windows 7 32/64-bit
• Microsoft Windows Vista 32/64-bit
• Microsoft Windows XP 32/64-bit
• Microsoft Windows Server 2012
• Microsoft Windows Server 2008
• Microsoft Windows Server 2003
• Microsoft Windows Server 2000
• Linux driver (built into the OS)
• DOS NDIS2
• DOS Diagnostic Program (configures Flow Control)
• Packet driver
• Netware Server v6.x/5.x
• Netware ODI driver for DOS
• UnixWare 7.x
Additional Functions
• Wake-on-LAN:
Active high
Active low
Positive pulse
Negative pulse
Diagnostic LEDs
• 100M (speed)
• LINK/ACT
Physical Parameters
Dimensions
• 120 x 20 mm
Power Consumption
• Max: 0.37 W
Temperature
• Operating: 0 to 40 В°C
• Storage: -25 to 55 В°C
Humidity
• Operating: 5 to 90% non-condensing
Certifications
• CE Class B
• FCC Class B
• C-Tick
Sertifikaadid
Sidustooted
