DFL-1000EOL EOS
Network Secure Firewall for Workgroups
Kirjeldus
Complete Security
Your  office is connected to the outside world through the Internet. It is  easy for hackers  to intrude your  databases to steal or destroy data. The DFL-1000 provides a wide range of  protection against outside attacks,  plus comprehensive security that  includes user authentication,  scheduled policies and Virtual  Server Mapping. The DFL-1000 provides NAT translation of IP addresses from the internal private network to the public IP network.
Content Filtering & Virus Scanning
The DFL-1000 provides  filtering of potentially malicious codes embedded in web pages to remove Active objects, java, JavaScript and other potential threats.  It provides virus scanning for  all incoming and outgoing email and attachments, plus virus  check for Web plug-ins and downloaded Web content.
Easy Installation
All you need to do is  connect the network cables. To the outside world, you hook the RJ-45 plug to your  DSL/cable modem, Internet  gateway or router . To your office, you plug in another  RJ-45 jack to your network switch or hub.  The DMZ port connects to an independent hub or switch for the DMZ network. The DFL-1000 provides CPU, system memory and embedded software, all ready to run.
Access Control
Administration access can be controlled such that the DFL-1000 can be administered from the protected internal network or the external public Internet. The DFL-1000 supports an internal/External (RADIUS)  database for authenticating user access to various services. It maps public IP addresses to information servers on the internal network to allow public access. It also prevents access to particular web sites, using powerful pattern matching to block access to URLs.
Scheduled Policies
Firewall policies may be scheduled for  different times of the day/week/month and for one time use or  recurring.
LAN-to-LAN VPN Connection
The DFL-1000 supports VPN functions including IPSec, ESP security in tunnel  mode, LAN to-LAN and mobile remote access.
Hardware Acceleration
The DFL-1000 uses  a special design ASIC to perform VPN encryption  and decryption. It off-loads CPU loading through hardware-based acceleration.
Management
The DFL-1000 supports web-based management using a secure SSL connection from a remote terminal either  on the internal  corporate network or  even from an external remote site.  The DFL-1000 can also be administered on-site using its RS-232 serial connection.
Põhiomadused
Sertifikaadid
Sidustooted
Pildid
DFL-1000
Eestvaade
Failid
Vaadake samuti
