DWM-321Projektideks
4G LTE wireless router with one module for two SIM cards and GLONASS/GPS support
Kust osta
Kirjeldus
The D-Link DWM-321 wireless router has one LTE Cat. 4 interface and provides 3G/4G connection with up to 150 Mbps downlink speed and up to 50 Mbps uplink speed. The DWM-321 is an in-vehicle hotspot device, which allows passengers to get Internet access with wireless devices. In addition, you can use the DWM-321 to organize meetings, seminars, conferences and other events out of the office. The router has two USIM/SIM slots allowing you to use a USIM/SIM card with the most efficient billing plan and backup mobile connection if one of the mobile operators malfunctions (you can switch to redundant conection through the Web UI).
Versatile Usage
With WAN port and 3G/4G support, the DWM-321 allows you to backup wired connection with mobile connection and vice versa, and provide load balancing. Wide range of operating temperatures (-30 to 70 °C) allows you to use the DWM-321 in harsh environmental conditions.
GNSS Antenna*
You can connect the GNSS antenna* to the DWM-321 and track location of the vehicle and analyse its traffic route in details.
* The GNSS antenna is not included in the package contents.
Põhiomadused
Device Interfaces
• One 10/100/1000Base-T WAN/LAN port
• Two 10/100/1000Base-T LAN ports
• Two USIM/SIM slots
• Terminal block with PWR, GND, DI-1, DI-2, DO, IGN, Tx, Rx pins
LEDs
• GNSS
• PWR
• 2.4G
• 5G
• SIM A, SIM B (CELL 1)
• SIM A, SIM B (CELL 2)
Buttons
• Reset button
Antenna
• Two connectors for LTE external antennas
• One connector for GNSS antenna*
• Two connectors for Wi-Fi antennas
4G LTE Module
• One 4G LTE module
Wireless Standards
• IEEE 802.11b/g/n/ac
Wireless Security
• WEP
• WPA/WPA2
• WPA/WPA2-PSK
• 802.1x authentication
Wireless Speed
• Up to 850 Mbps – 5 GHz
• Up to 300 Mbps – 2.4 GHz
Frequency Range
• LTE FDD: B1/B3/B5/B7/B8/B20
• LTE TDD: B38/B40/B41
• WCDMA: B1/B5/B8
• GSM: B3/B8
4G Connection Speed
• Downlink speed: 150 Mbps
• Uplink speed: 50 Mbps
Operation Modes
• AP
• Router
• WDS
• WDS AP
Router Features
• IPv4/v6 support
• VPN/VLAN
• RIP1/RIP2, OSPF, BGP Routing
• Dual-SIM configuration
• WAN failover
Security
• VPN**: IPSec, OpenVPN, PPTP/L2TP, GRE tunneling
• Firewall: SPI, IPS
• Access Control: Packet Filter, URL Blocking, MAC Filter, Content Filter, Application Filter
• Authentication: Captive Portal, MAC authentication
Management and monitoring
• Web UI
• CLI
• SNMP agent (SNMPv2/v3)
Physical Parameters
Dimensions (L x W x H)
• 160 x 125 x 47 mm
Power
• 9 to 36 V DC
Temperature
• Operating: -30 to 70°C
• Storage: -40 to 85°C
Humidity
• Operating: 10% to 95% non-condensing
• Storage: 0% to 95% non-condensing
Certifications
• RoHS
** The functionality will be available in future firmware versions (the OpenVPN, PPTP/L2TP, GRE tunneling is absent in version 3.0.0).
Füüsilised parameetrid
Sertifikaadid
Sidustooted
DWM-321  4G LTE wireless router with one module for two SIM cards and GLONASS/GPS support
Pildid
DWM-321
Paremvaade
Tagantvaade
Tagantvaade
Failid
Vaadake samuti
