Kiirotsing
Toote omadused:
4G LTE wireless router with one module for two SIM cards and GLONASS/GPS support
Projektideks
Põhiomadused:
Device Interfaces
• One 10/100/1000Base-T WAN/LAN port
• Two 10/100/1000Base-T LAN ports
• Two USIM/SIM slots
• Terminal block with PWR, GND, DI-1, DI-2, DO, IGN, Tx, Rx pins
LEDs
• GNSS
• PWR
• 2.4G
• 5G
• SIM A, SIM B (CELL 1)
• SIM A, SIM B (CELL 2)
Buttons
• Reset button
Antenna
• Two connectors for LTE external antennas
• One connector for GNSS antenna*
• Two connectors for Wi-Fi antennas
4G LTE Module
• One 4G LTE module
Wireless Standards
• IEEE 802.11b/g/n/ac
Wireless Security
• WEP
• WPA/WPA2
• WPA/WPA2-PSK
• 802.1x authentication
Wireless Speed
• Up to 850 Mbps – 5 GHz
• Up to 300 Mbps – 2.4 GHz
Frequency Range
• LTE FDD: B1/B3/B5/B7/B8/B20
• LTE TDD: B38/B40/B41
• WCDMA: B1/B5/B8
• GSM: B3/B8
4G Connection Speed
• Downlink speed: 150 Mbps
• Uplink speed: 50 Mbps
Operation Modes
• AP
• Router
• WDS
• WDS AP
Router Features
• IPv4/v6 support
• VPN/VLAN
• RIP1/RIP2, OSPF, BGP Routing
• Dual-SIM configuration
• WAN failover
Security
• VPN**: IPSec, OpenVPN, PPTP/L2TP, GRE tunneling
• Firewall: SPI, IPS
• Access Control: Packet Filter, URL Blocking, MAC Filter, Content Filter, Application Filter
• Authentication: Captive Portal, MAC authentication
Management and monitoring
• Web UI
• CLI
• SNMP agent (SNMPv2/v3)
Physical Parameters
Dimensions (L x W x H)
• 160 x 125 x 47 mm
Power
• 9 to 36 V DC
Temperature
• Operating: -30 to 70°C
• Storage: -40 to 85°C
Humidity
• Operating: 10% to 95% non-condensing
• Storage: 0% to 95% non-condensing
Certifications
• RoHS
* The GNSS antenna is not included in the package contents.
** The functionality will be available in future firmware versions (the OpenVPN, PPTP/L2TP, GRE tunneling is absent in version 3.0.0).
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
