DIR-300/NRU/B6EOL EOS
Wireless N150 Router
Kirjeldus
Wireless Interface
Using the DIR-300NRU device, you are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 150Mbps).
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-300NRU includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Easy configuration and update
You can configure the settings of the wireless router DIR-300NRU via the user-friendly web-based interface (the interface is available in several languages).
Now you can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
Põhiomadused
Hardware
Interfaces
• 10/100BASE-TX WAN port
• 4 10/100BASE-TX LAN ports
LEDs
• POWER
• INTERNET
• WLAN
• 4 LAN LEDs
• WPS
Buttons
• RESET button to restore factory default settings
• WPS button to set up secure wireless connection
Antenna
• External non-detachable omnidirectional antenna (2dBi gain)
Power connector
• Power input connector (DC)
| Software | |
WAN connection types
• PPPoE
• Static IP / Dynamic IP
• PPPoE + Static IP / Dynamic IP
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
Network functions
• DHCP server/relay
• DNS relay
• Dynamic DNS
• Static IP routing
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
• Manual speed and duplex mode setup for each Ethernet port
• Flow control
Firewall functions
• IP filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Built-in Yandex.DNS web content filtering service
VPN
• IPSec/PPTP/L2TP/PPPoE pass-through
Management
• Local and remote access to settings through TELNET/WEB (HTTP)
• Multilingual web-based interface for configuration and management
• Support of remote logging
• Ping utility
• Traceroute utility
• TR-069 client
| Wireless Module Parameters | |
Standards
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of client mode
• WMM (Wi-Fi QoS)
• Managing connected stations
• Advanced settings
Wireless connection rate
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n: from 6.5 to 150Mbps (from MCS0 to MCS7)
Transmitter output power
• 802.11b (typical at room temperature 25 °C)
17dBm (+/-2dB) at 1, 2, 5.5, 11Mbps
• 802.11g (typical at room temperature 25 °C)
17dBm (+/-2dB) at 6, 9, 12, 18, 24, 36Mbps
16dBm (+/-2dB) at 48Mbps
15dBm (+/-2dB) at 54Mbps
• 802.11n (typical at room temperature 25 °C)
16dBm (+/-2dB) at MCS0/1/2
15dBm (+/-2dB) at MCS3/4
13dBm (+/-2dB) at MCS5/7
Receiver sensitivity
• 802.11b (typical at PER = 8% at room temperature 25 °C)
-90dBm at 1Mbps
-88dBm at 2Mbps
-87dBm at 5.5Mbps
-86dBm at 11Mbps
• 802.11g (typical at PER = 10% at room temperature 25 °C)
-84dBm at 6Mbps
-82dBm at 9Mbps
-80dBm at 12Mbps
-78dBm at 18Mbps
-77dBm at 24Mbps
-74dBm at 36Mbps
-70dBm at 48Mbps
-68dBm at 54Mbps
• 802.11n (typical at PER = 10% at room temperature 25 °C)
HT20
-93dBm at MCS0
-90dBm at MCS1
-88dBm at MCS2
-85dBm at MCS3
-82dBm at MCS4
-78dBm at MCS5
-77dBm at MCS6
-76dBm at MCS7
HT40
-90dBm at MCS0
-87dBm at MCS1
-85dBm at MCS2
-82dBm at MCS3
-79dBm at MCS4
-75dBm at MCS5
-74dBm at MCS6
-73dBm at MCS7
Modulation schemes
• 802.11b: DQPSK, DBPSK, CCK
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
Physical Parameters
Dimensions
• 113.2 x 147.5 x 31.5 mm (4.5 x 5.8 x 1.2 in)
Weight
• 246 g (0.54 lb)
Operating Environment
Power
• Output: 5V DC, 1A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -20 to 65 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Delivery Package
• Router DIR-300NRU
• Power adapter DC 5V/1A
• Ethernet cable
Sertifikaadid
Sidustooted
DIR-300/NRU/B6 Wireless N150 Router
