DIR-880L/A1AEOL EOS
Kahesageduslik gigabit AC1900 mydlink-toega ruuter
Kirjeldus
Wireless Dual Band Gigabit Router DIR-880L provides a simple connection management and network monitoring. Using AC SmartBeam technology significantly improves the performance and advanced features Quality of Service (QoS) can effectively allocate bandwidth. Support mydlink cloud service and application usage SharePort router provides shared access to media content and streaming. With its stylish design, easy use and support of IPv6 Router DIR-880L is the perfect solution to work in networks today and in the future.
Fast and reliable networking
Dual Band Gigabit Router DIR-880L allows you to combine all of the computers and mobile devices in a single home network with broadband Internet access. Using AC SmartBeam technology increases the speed of data transfer and increases network coverage. Simultaneous dual-band allows for streaming HD-video, make Internet phone calls, and view Web-page without delay.External antenna with high gain improves signal reception, ensuring a reliable connection anywhere in your home. Gigabit Ethernet ports provide high-speed wired connection of up to 4 computers or other devices.
Mydlink service
The router supports cloud service mydlink, which enables remote access, view and control devices, regardless of your location. The service mydlink you can view information about the users who are connected to the router, change the settings to block certain users from any computer, tablet or smartphone connected to the Internet. In addition, parents can monitor and control the sites that their children attend.
Sharing files with one touch
With the application SharePort, installed on your mobile device, you can quickly access documents, movies, pictures and music on a USB-drive connected to the router DIR-880L. You can download your music library on the USB-drive and choose to share files from anywhere in the house 2 . You can also view photos on a TV screen, while the rest of the family watching movies on their mobile devices. The user can organize media streaming to multiple devices or download them to your device for later playback offline. The intuitive user interface provides quick access to various features and applications stored on your drive.
Reliability and efficiency
Router DIR-880L supports the latest wireless standard 802.11ac, which provides data transfer rates up to 1.9 Gb / s 1 (1300AC + 600N). In addition, DIR-880L supports simultaneous dual-band 2.4 GHz and 5 GHz and is equipped with three external antennas. Dual band allows you to browse Web-page, chat with friends and check e-mail, using a frequency of 2.4 GHz, while the frequency of 5 GHz can be used for streaming media content, online gaming and Internet calling commit. QoS mechanism allows you to prioritize mission-critical data, such as streaming video and online games; Band steering function provides efficient load balancing between the two ranges, and through the use of ether functions fairness (airtime fairness) each wireless client receives the necessary bandwidth.
Easy Installation and Setup
By the application of QRS (Quick Router Setup) Mobile, installed on your smartphone or tablet, you can quickly and easily launch and perform remote management of the router. Simply plug in the router, open the application and follow a few simple steps to connect without using a computer. In addition, the security of the network can be configured one-touch WPS. If there are devices with mydlink cloud service, you can use an automatic setting Zero Configuration. To do this, simply connect the device to support cloud service mydlink to DIR-880L, and the router will be automatically added to your account without making any adjustments.
1 Maximum wireless signal rate derived from the specifications of the standard IEEE 802.11ac (draft). Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual throughput. On the range of the wireless network factors may adversely affect the environment.
2 File sharing is only used on the local network
Põhiomadused
Device interfaces
• 802.11 a/b/g/n/ac (draft) Wireless LAN
• 4 LAN 10/100/1000 Mbit/s ports
• 1 WAN 10/100/1000 Mbit/s port
• 2 USB ports (1 USB 3.0 port and 1 USB 2.0 port)
Antenna type
• 3 dual band dipole antennas
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3u
Minimum system requirements
• Windows 8/7/Vista/XP SP3 / Mac OS X 10.4 or above
• Microsoft Internet Explorer 6 or above, Firefox 1.5 or above, or other Java-enabled browser
• Ethernet network interface
• Cable/DSL modem
• ISP services subscription
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• IEEE 802.11n (5 GHz): 19.5~450 Mbit/s
• IEEE 802.11ac (5 GHz): 6.5~1300 Mbit/s
Advanced features
• Guest Zone
• File access over Internet with SharePort™ application
• Multilingual Web-based Setup Wizard
• Green Ethernet technology
• DLNA media server support
• AC SmartBeam technology
• Bridge mode
• Firewall
• VPN passthrough/multi-session PPTP/L2TP/IPSec modes
• QoS advanced features
• VPN server - L2TP over IPSec
mydlink features
• Remote management
• Viewing of current information outbound/inbound conection bandwidth
• Viewing of currently connected clients
• Viewing of browser history for each client
• Blocking/unblocking of network access for a client
• Wireless network management
• Access via Web browser or mobile application for iOS or Android
Mobile application support
• mydlink Lite
• mydlink SharePort
• QRS Mobile v1.5
Wireless security
• WPA and WPA2 (Wi-Fi Protected Access)
• Wi-Fi Protected Setup (WPS) PIN/PB
