Kiirotsing
Toote omadused:
Traadita kahesüsteemne 2.4/5GHz VPN-toega ruuter-tulemüür, 2xWAN, 4 port LAN 10/100/1000Base-TX
EOL
Põhiomadused:
Liidesed
• Ethernet:
+ 2 WAN porti 10/100/1000 Mbps
+ 4 LAN porti 10/100/1000 Mbps
• Traadita
+ 802.11 b / g / n (SSB)
+ 3 välist eemaldatavat antenni,  2 dBi
• 2 USB 2.0 porti
• Console: 1 RJ-45
Jõudlus
• Firewall Throughput: 130 Mbps
• VPN  Throughput: 100 Mbps
• Concurrent Sessions: 60,000
• New Sessions (per second): 600
• Firewall Policies: 600
Interneti ühendustüübid
• Static/Dynamic IP
• PPPoE/ L2TP/ PPTP
• Multiple PPPoE
Tulemüür
• Static Route
• Dynamic Route: RIP v1, RIP v2, OSPF
• Dynamic DNS
• Inter-VLAN Route
• NAT,PAT
• Web Content Filtering
• Intrusion Prevention System (IPS)
Võrk
• DHCP Server/Klient
• DHCP Relay
• IEEE802.1q VLAN
• VLAN (port-based)
• IP Multicast: IGMP Proxy
• IPv6
• Route Failover
• Outbound Load Balancing
Traadita
• Multiple Service Set Identifier (SSID)
• Service Set Identifier (SSID) to VLAN Mapping
• Wireless Security: Wired Equivalent Privacy (WEP), Wi-Fi Protect Setup (WPS), Wi-Fi Protected Access – Personal (WPA-PSK), Wi-Fi Protected Access – Enterprise  (WPA-EAP), Wi-Fi Protected Access version 2 – Personal (WPA-PSK), Wi-Fi Protected Access version 2 – Enterprise (WPA-EAP)
VPN
• VPN Tunnels: 70
• Encryption Methods: DES, 3DES, AES, Twofish, Blowfish, CAST-128, NULL
• IPSec/PPTP, L2TP Server
• PPTP/l2TP Clients: 25/25
• IPSec NAT Traversal
• Dead Peer Detection
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
SSL VPN
• SSL VPN Tunnel: 20
• SSL Encryption Methods: DES, 3DES, AES
• SSL Message Integrity: MD5, SHA1
Bandwidth Management
• Max. Bandwidth Control
• Priority Bandwidth Control: Port Based QoS, 3 Classes
System Management
• Web-based User Interface: HTTP, HTTPS
• Command Line
• SNMP: v1, v2c, v3
Füüsilised parameetrid
Power Supply
Internal Power Supply Unit, DC 12 V / 2.5 A
Max. Power Consumption
19.3 W
Dimensions (L x W x H)
180 x 280 x 44 mm
Operation Temperature
0 to 40 °C
Storage Temperature
-20 to 70 °C
Operation Humidity
5% to 95% Non-condensing
EMI/EMC
FCC Class B, CE Class B, C-Tick, IC
Safety
cUL, LVD (EN60950-1)
MTBF
260,000 hours
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
