Kirjeldus
BASIC WIRELESS CONNECTIVITY
Connect to your wireless network from your desktop PC using the DWA-510 Wireless G Desktop Adapter and browse the web, check e-mail, and chat with friends and family online. The Wireless G Desktop Adapter offers simple network connectivity without the hassle of running a network cable.
BASIC SECURITY PROTECTION
To protect your data and privacy, the Wireless G Desktop Adapter supports WEP and WPA encryption for connecting to a secure wireless network.
COMPATIBILITY ASSURANCE
The Wireless G Desktop Adapter is based on the 802.11g standard and is backwards compatible with 802.11b, ensuring compatibility with a wide range of wireless routers and networks.
EASY TO INSTALL & CONNECT
D-Link’s Quick Setup Wizard provides easy setup for this desktop adapter. The addition of the Wi-Fi Protected Setup (WPS) function provides advanced security features that remain simple enough for the average user to confgure correctly. This function allows for devices to undergo an easy one-time click-button confguration for establishing connection with an access point or wireless router without the need of manually setting up complex encryption codes
Põhiomadused
Minimaalsed nõuded süsteemile
Standardid
Liides
Sagedusdiapasoon
Modulatsiooni skeemid
Andmeedastuskiirus
Vastuvõtja tundlikkus (802.11b, PER 8%)
Vastuvõtja tundlikkus (802.11g, PER 10%)
Saatja väljundvõimsus (802.11b, temperatuuril 25 С)
Saatja väljundvõimsus (802.11g, temperatuuril 25 С)
Antenn
Üks eemaldatav ring dipoolantenn võimendusteguriga 2dBi
Turvalisus
Quality of service (QoS)
Toetatavad operatsioonisüsteemid
Windows 98 SE, ME, 2000, XP, Vista
