DWA-510EOL EOS
Juhtmevaba PCI-adapter 802.11g, kuni 54 Мbit/s
Kust osta
Kirjeldus
BASIC WIRELESS CONNECTIVITY
Connect to your wireless network from your desktop PC using the DWA-510 Wireless G Desktop Adapter and browse the web, check e-mail, and chat with friends and family online. The Wireless G Desktop Adapter offers simple network connectivity without the hassle of running a network cable.
BASIC SECURITY PROTECTION
To protect your data and privacy, the Wireless G Desktop Adapter supports WEP and WPA encryption for connecting to a secure wireless network.
COMPATIBILITY ASSURANCE
The Wireless G Desktop Adapter is based on the 802.11g standard and is backwards compatible with 802.11b, ensuring compatibility with a wide range of wireless routers and networks.
EASY TO INSTALL & CONNECT
D-Link’s Quick Setup Wizard provides easy setup for this desktop adapter. The addition of the Wi-Fi Protected Setup (WPS) function provides advanced security features that remain simple enough for the average user to confgure correctly. This function allows for devices to undergo an easy one-time click-button confguration for establishing connection with an access point or wireless router without the need of manually setting up complex encryption codes
Põhiomadused
Minimaalsed nõuded süsteemile
  • Windows 98 SE, ME, XP SP2, 2000 SP4 või Vista
  • CD-ROM lugeja
  • 20 МB vaba ruumi kõvaketal
  • Vaba PCI pesa
    Standardid
  • IEEE 802.11g
  • IEEE 802.11b
    Liides
  • PCI 2.3
    Sagedusdiapasoon
  • 2412 – 2472 МHz
    Modulatsiooni skeemid
  • 802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDM
    Andmeedastuskiirus
  • 802.11g: 6/9//12/18/24/36/48/54 Мbit/s
  • 802.11b: 1/2/5.5/11 Мbit/s
    Vastuvõtja tundlikkus (802.11b, PER 8%)
  • 11 Мbit/s: -85dBm
  • 2 Мbit/s: -90dBm
    Vastuvõtja tundlikkus (802.11g, PER 10%)
  • 6 Мbit/s: -85dBm
  • 54 Мbit/s: -70dBm
    Saatja väljundvõimsus (802.11b, temperatuuril 25 С)
  • 11, 5.5, 2 ja 1 Мbit/s: 17 dBm (+/- 2dBm)
    Saatja väljundvõimsus (802.11g, temperatuuril 25 С)
  • 54 Мbit/s: 13dBm
  • 48 Мbit/s: 13dBm
  • 36 Мbit/s: 13dBm
  • 24,18, 12, 9, 6 Мbit/s: 13dBm
    Antenn
    Üks eemaldatav ring dipoolantenn võimendusteguriga 2dBi
    Turvalisus
  • 64/128-bitine WEP-andmekrüpteerimine
  • Wi-Fi Protected Access (WPA/ WPA2-PSK, WPA/WPA2-EAP
  • 802.1x
    Quality of service (QoS)
  • 802.11e
  • WMM
    Toetatavad operatsioonisüsteemid
    Windows 98 SE, ME, 2000, XP, Vista
  • Füüsilised parameetrid
     Indikaatorid
  • Act
  • Link
    Töövõimsus
  • 3.3 V alalisvool +/- 10% või 5 V alalisvool +/- 10%
    Tarbitav vool
  • Saatmise režiimis (continuous transmit mode): 450 mА
  • Vastuvõtu režiimis (continuous receive mode): 260 mА
  • Magamisrežiimis (sleep mode): 40 mА
    Mõõdud
  • 126 x 120 x 19 mm
    MTBF
    >30 000 t
    Töötemperatuur
    0˚ kuni 40˚C
    Säilitamistemperatuur
    -20˚ kuni 65˚C
    Tööniiskus
    10% kuni 90%, ilma kondensatsioonita
    Säilitamisniiskus
    5% kuni 95%, ilma kondensatsioonita
    Sertifikaadid
  • FCC Class B
  • CE
  • C-Tick
  • Sertifikaadid
    Sidustooted
    Pildid
    DWA-510
    Eestvaade
    Failid
    Vaadake samuti
