DUB-1325Uus
Hub with two USB 3.0 ports, USB Type-C port, SD and microSD card slots and USB 3.0 connector
Kust osta
Kirjeldus
The D-Link DUB-1325 Hub with USB 3.0 connector provides an easy way to connect up to three USB devices to your notebook or desktop computer and allows you to insert SD and microSD cards into the corresponding slots.
Add Three USB Ports to Your Computer
With the DUB-1325 Hub, you can conveniently add two USB 3.0 ports and one USB Type-C port to connect up to three USB peripheral devices to your PC. USB 3.0 technology supports data rates of up to 5 Gbps, which means that you can enjoy faster transfer speeds compared to previous USB standards.
Dual Slot SD Card Reader
The DUB-1325 Hub is equipped with the SD and microSD card slots. Use the dual slot card reader to access data on a SD and microSD card simultaneously.
Plug-and-play support
Simply connect the DUB-1325 to any PC (you can also plug in the power adapter if it is necessary). It’s that easy - no drivers or software installation is required.
Põhiomadused
Interfaces
• Two USB 3.0 Type-A ports
• One USB Type-C port (for data transmission only)
• SD card slot
• microSD card slot
• One USB 3.0 Type-A connector
LEDs
• Power LED
Standards
• USB 3.0 for Type-C
• USB 3.0
• USB 2.0
• USB 1.1
• OHCI
• UHCI
• EHCI
• xHCI
Data rate
• Up to 5 Gbps
Connectivity rules
• Up to 127 devices
• Hub cascading
System requirements
• Available USB port (USB 3.0 is recommended)
• Windows XP/Vista/7/8/10, Mac OS, Linux
Physical Parameters
Dimensions (L x W x H)
• 108 x 35 x 13.5 mm
Power input
• From PC (USB bus powered)
• 5 V / 2 A DC power adapter (Micro-USB)
Temperature
• Operating: 0 to 40 °C
• Storage: -20 to 70  °C
Humidity
• Storage: 5% to 90% non-condensing
Füüsilised parameetrid
Sertifikaadid
Sidustooted
DUB-1325  Hub with two USB 3.0 ports, USB Type-C port, SD and microSD card slots and USB 3.0 connector
Pildid
DUB-1325/Ax
Eestvaade
Eestvaade
Tagantvaade
Failid
Vaadake samuti
