Kiirotsing
Toote omadused:
PoE-ga megapiksel IP kaamera
Põhiomadused:
Hardware profile camera
• megapixel 1/4-inch CMOS-sensor
• A lens with a focal length of 2,8-12 mm
• Aperture: F1.4
• Built-in ICR filter
• Shutter speed: 1/5 to 1/10, 000 sec
• Min. illumination: 0.1 Lux (color mode), 0.05 Lux (B / W)
• Angles:
  • 77,5-22,7 (horizontal)
  • 53,3-14,5 (vertical)
  • 82,5-27 (diagonal)
• Minimum Object Distance: 0.2 m
Image characteristics
• Setting the image size and quality, frame rate and bit rate
• The timings and paste text
• 3 configurable motion detection windows
• 5 customizable zones of private masks
• Adjust brightness, color saturation, contrast and sharpness
Video Compression
• Compression formats H.264/MPEG-4/MJPEG
• Multicast streaming video formats H.264/MPEG-4
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 800, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176 and 30 frames / s 1
• 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240 and 30 frames / s 1
Audio Support
• Audio Encoding MPEG-4 AAC, transfer rate: 16 kbit / s to 128 kbit / s
• Audio Coding G.711, bit rate: 8 kbit / s to 64 kbit / s
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet
• Supports 802.3af PoE
• Connectors DI / DO for external devices
• RS-485 port for connecting external devices / tilt
• Card slot Micro SD / SDHC
• External audio-vhod/vyhod
Network Protocols
• IPv4
• IPv6
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-Client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• 802.1x
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering IP-addresses
• QoS
• CoS
• Multicast
• IGMP
• ONVIF
• SNMP v1/v2/v3
Safety
• Security administrator account and user groups
• Password authentication
• HTTPS encryption to access the web-based interface
• HTTP and RTSP authentication
System requirements for the web-based interface
Web-browser: Internet Explorer, Firefox, Chrome
Event Management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via email or FTP
• Support for multiple SMTP servers, and FTP
• Multiple event notifications
• Several ways to create backups
Remote management
• Create stop-kadrov/videoklipov and save to a local hard disk through Web-browser
• Interface settings, available through the web-browser
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 8/7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
The software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen: up to 32 cameras
• Recording Options for triggering a sensor or manually
• Supports all management functions available through the Web-based interface
Füüsilised parameetrid
Weight
150 grams
Nutrition
12 VDC, 1.5 A, 802.3af PoE
Power consumption
Max. 2.88 W (PoE)
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 70 C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Measurements
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
