DWL-3600APEOL EOS
Traadita pääsupunkt 802.11n,kuni 300 Mbit/s
Kirjeldus
The DWL-3600AP Unified 802.11n Access Point is an indoor 802.11n Wi-Fi access point designed specifically for deployment in business environments. Highly manageable and capable of high data transmission speeds, the DWL-3600AP integrates seamlessly into existing network infrastructure and can be easily scaled up to meet future demands.
High Performance
The DWL-3600AP’s 2x2 MIMO 2.4GHz radio delivers up to 300 Mbps of network throughput. In addition, the DWL-3600AP features RadioProtect technology, which ensures all users receive an adequate level of service even in an environment where many users are accessing the network through legacy 802.11b and 802.11g devices.
Self-Configuring Cluster
For small businesses that need to deploy multiple access points (APs) but lack the resources to tackle the complicated task of network management, the DWL-3600AP’s self-configuring cluster feature offers the ideal solution. When a small number of DWL-3600APs is deployed on the network, they may be configured to form a self-configuring cluster. Once the administrator is through with configuring one access point, the same configuration can then be applied to all remaining APs. Up to 16 APs may be used to form a cluster.
Unified Management
When deployed in conjunction with D-Link’s line of Unified Wireless Switches, up to 256 DWL-3600AP units may be centrally managed and provisioned, thus enabling the administrator to expand the Wi-Fi network to cover a large area.
Security
The DWL-3600AP supports the latest standards in Wi-Fi security, including WPA, WPA2, and 802.1X. In addition, the DWL-3600AP supports up to 16 virtual access points (VAP), which allows the administrator to assign different access privileges to different groups of users. When used together with D-Link’s line of Unified Wireless Switches, security can be raised to a new level. Rogue APs in the network may be easily detected, and the administrator will be immediately notified of any security threat.
Automatic RF Management
When a number of access points are deployed close to each other, interference may result if proper RF management is not implemented. When a DWL-3600AP senses a neighbor nearby, it will automatically select a non-interfering channel. This greatly reduces RF interference and will allow the administrator to deploy APs more densely. To further minimize interference, when a nearby AP is operating on the same channel, the DWL-3600AP will automatically lower its transmission power. When, for whatever reason, the nearby AP is no longer present, the DWL-3600AP will increase its transmit power to expand coverage.
Quality of Service
The DWL-3600AP is WMM-certified, so in the event of network congestion, time-sensitive traffic can be given priority ahead of the rest of traffic. Furthermore, when a number of DWL-3600APs are in close proximity with each other, an access point will refuse new association requests once its resources are fully utilized. Instead, the association request will be picked up by a neighboring unit. This feature ensures that no single AP is overburdened while others nearby sit idle.
Põhiomadused
System
• Wireless Interface: 802.11b/g/n 2,4 GHz 2x2 MIMO
• Interface LAN: 10/10/100 Gigabit Ethernet
• Antenna: Internal antenna 4
• Antenna Gain: 4,7 dBi
• Supply: IEEE 802.3af Power Over Ethernet or external power adapter
Frequency
• 2.4 GHz - 2.497 GHz
Data transfer rate
• 802.11n:
6.5 Mbit / s - 130 Mbit / s (20 MHz)
6.5 MHz - 300 Mbit / s (40 MHz)
• 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11b: 11, 5.5, 2 and 1 Mbit / s
Transmitter output power
• 802.11b:
21 dBm at 1, 2, 5.5, 11 Mbit / s
• 802.11g:
21 dBm at 6 Mbit / s ~ 24 Mbit / s
19 dBm at 36 dBm at Mbit/s18 48 Mbit / s
17 dBm at 54 Mbit / s
• 802.11n (2,4 GGts/HT-20):
20 dBm at MCS0 / 8
20 dBm at MCS1 / 9
20 dBm at MCS2/10
20 dBm at MCS3/11
19 dBm at MCS4/12
18 dBm at MCS5/13
17 dBm at MCS6/14
16 dBm at MCS7/15
• 802.11n (2,4 GGts/HT-40)
19 dBm at MCS0 / 8
19 dBm at MCS1 / 9
19 dBm at MCS2/10
19 dBm at MCS3/11
17 dBm at MCS4/12
16 dBm at MCS5/13
14 dBm at MCS6/14
14 dBm at MCS7/15
Receiver Sensitivity
• 802.11b:
-89 DBm at 2 Mbit / s
-84 DBm at 11 Mbit / s
• 802.11g:
-85 DBm at 6 Mbit / s
-84 DBm at 9 Mbit / s
-84 DBm at 12 Mbit / s
-82 DBm at 18 Mbit / s
-78 DBm at 24 Mbit / s
-73 DBm at 36 Mbit / s
-70 DBm at 48 Mbit / s
-68 DBm at 54 Mbit / s
- 82dBm at MCS0 / 8
- 79dBm at MCS1 / 9
- 77dBm at MCS2/10
- 74dBm at MCS3/11
- 70dBm at MCS4/12
- 66dBm at MCS5/13
- 65dBm at MCS6/14
- 64dBm at MCS7/15
-79 DBm at MCS0 / 8
-76 DBm at MCS1 / 9
-74 DBm at MCS2/10
-71 DBm at MCS3/11
-67 DBm at MCS4/12
-63 DBm at MCS5/13
-62 DBm at MCS6/14
-61 DBm at MCS7/15
Security
• SSID: 16 SSID, Station Isolation
• Safety:
+ WEP
+ Dynamic WEP
+ WPA Personal / Enterprise
+ WPA2 Personal / Enterprise
• Detection and Prevention:
+ Classification of unauthorized access points and unauthorized
• Authentication:
+ Filtering by MAC-addresses
+ 802.1x
System control
• Web-User Interface: HTTP / HTTPS
• Command line: SNMP, SSH, Telnet
