DNS-327LEOL EOS
2-kettaavaga võrgu kettaseade
Kirjeldus
The DNS-327L ShareCenter™ + 2-Bay Cloud Network Storage Enclosure is an easy-to-use solution for accessing, sharing, and backing up your important data by creating your own personal cloud. Keep all of your data safely stored and protected at home, and still have it at your fingertips with a sleek, award-winning NAS solution.
Share Your Files from Anywhere
The ShareCenter™ + 2-Bay Cloud Network Storage Enclosure includes a web enabled file server which allows you to download your documents, photos, and other multimedia files from wherever you are. Once configured, simply log into your ShareCenter using the friendly web user interface to view a list of available files.
You can also connect to the DNS-327L with the mydlink Access - NAS app to access and play music, watch videos, and view photos directly on your mobile device. With the mydlink portal, you’ll never have to bother with configuring complicated network settings to enable remote access to your content.
Easy Installation and Set Up
The DNS-327L can accept 3.5” internal SATA hard drives up to 4 TB, and installing drives is as simple as popping the top, attaching the hard drive holders, and then sliding them into place. Push the latch button to access the drive bays, then just slide in your storage drives into place and you’re ready. A convenient USB port on the back of the ShareCenter can be used to attach a multifunction USB printer, an Uninterruptible Power Supply (UPS), or an external USB storage drive to use with the one-touch backup function.
Combined with a D-Link Cloud Router, the DNS-327L can also take advantage of Zero Configuration Setup. Zero Configuration technology greatly simplifies the configuration of your DNS-327L. Simply choose the RAID type you need and the Zero Configuration will do the rest for you.
Stream Digital Media With a Built-in Media Server
Back up your digital media files to the ShareCenter for safekeeping, and enjoy the benefits of the built-in DLNA® Certified UPnP AV media server. Stream digital content to compatible media players such as the PlayStation® 3, Microsoft® Xbox 360™, or directly to a smart TV. You can also enjoy photo, music, and video streaming remotely through mobile devices.
Powerful Performance and Flexibility
Four different hard drive modes are available (Standard, JBOD, RAID 0, RAID 1), which allow users to choose the configuration best suited to their needs. Standard mode creates two separately accessible hard drives. JBOD combines both drives to create a single, easy-to-use volume. RAID 0 combines both drives in a “striped” configuration, which provides maximum performance when using a Gigabit Ethernet connection. RAID 1 creates a copy of your data on both drives, providing maximum protection; if one drive fails, the unaffected drive continues to function as a single drive until the failed drive is replaced. The DNS-327L is hot-swap enabled, meaning you can easily replace a failed drive and your data will automatically be copied to the new drive, allowing the ShareCenter to return to its full level of protection and ensuring your files remain safe.
Põhiomadused
Standards
• IEEE 802.3
• IEEE 802.3ab
• IEEE 802.3u
• TCP / IP
• CIFS / SMB
• NFS
• AFP
• DHCP-Client
• DDNS
• NTP
• FTP over SSL / TLS, FXP
• HTTP / HTTPS
• LLTD
• PnP-X
• UPnP AV
• USB 3.0
• Bonjour
• WebDAV
Supported types of hard drives
• Internal 3.5 "SATA I / II - Support for hard disk capacity of 4 TB or more 1
Ports
• Port 10/100/1000 Gigabit Ethernet
• USB 3.0 port
• Power
Indicators
• Power
• USB
• LAN (on port LAN)
• HDD 1
• HDD 2
Disk Management
• Multiple hard drive configurations
- RAID 0
- RAID 1
- JBOD
- Standard
• Migration of RAID: from Standard to RAID 1
• The format of the file system: EXT4
• Scan Disk
• SMART
• Support for Advanced Format HDD (Advanced Format)
Account Management
• User Account Control
• Account Management teams
• Quota Management User / Group
• Network Access Control
• Management of mounting disk images
Manage downloads
• Schedule downloads on HTTP / FTP
• Download Peer to peer (P2P)
Backup Management
• Schedule a backup from PC to NAS (D-Link ShareCenter Sync)
• Schedule a local backup
• Schedule remote backup
• Supports Apple Time Machine
• Backup USB-devices
• Backup Storage Cloud (Amazon S3)
Device control
• Browser support:
- Internet Explorer 7 or above
- Mozilla Firefox 3 or higher
- Apple Safari 4 or higher
• The Wizard system (Win / Mac)
• Utility D-Link Storage (Win / Mac)
• Notification by e-mail
• Notification via SMS
• The journal system / FTP
Power Management
• Power Save Mode
• Automatic power recovery
• Turning the power on schedule
• Fan speed control
• Technology D-Link Green Ethernet
Remote file sharing
• File Web-server
• FTP-server
• WebDAV
• Access to your mobile device
• Access to the mydlink portal
File Sharing
• Max. number of user accounts: 256 people
• Max. the number of group accounts: 32 groups
• Max. the number of public folders, folder 128
• Max. Samba-concurrent connections: 64 connections
• Max. the number of simultaneous FTP-connections: 10 connections
