KVM-440
8-Port KVM Switch with VGA and USB Ports
Kirjeldus
The D-Link KVM-440 8-port KVM switch with VGA and USB ports allows you to manage up to eight computers with one monitor, one keyboard and one mouse. The KVM-440 requires no driver installation and no external power adapter connection. This KVM switch supports hot-plugging - you don't need to turn your computers off before installing the device. The KVM-440 allows you to switch between computers quickly and easily using the buttons located on the front panel, IR remote controller or desktop controller. The KVM-440 supports autoscan mode, which provides automatic switching to the next PC after the scan interval expires. Two USB ports can be used for connecting external devices, for example, USB-disk. This KVM switch can be mounted in a 19-inch rack with the included mounting brackets.
Põhiomadused
Hardware
Ports for connecting KVM cables
• 8 VGA ports
Ports for connecting management console
• Monitor (local): VGA
• Keyboard (local): USB Type-A
• Mouse (local): USB Type-A
Ports for connecting external devices
• 2 USB Type-A ports
Port for connecting smart desktop controller
• Mini-USB
KVM cable connectors for connecting PC
• Video: 15-pin HDB connector (VGA)
• Keyboard/Mouse: USB Type-A connector
LEDs
• 8 port LEDs for connected PCs
Buttons
• 8 port switching buttons
Enclosure
• Metal, 19-inch rack mountable
General Specifications
Connected PCs
• Up to 8
Autoscan mode
• Yes
Switching between PCs
• Switching buttons on the front panel
• IR remote controller
• Desktop controller
Sound notification of switching
• Yes
Max. resolution
• 1920x1440
Physical Parameters
Weight
• 2.37 kg
Dimensions (L x W x H)
• 370 x 83 x 30 mm
Environmental Conditions
Power Supply
• From USB port on PC (no external power adapter required)
Temperature
• Operating: -50 to 80 °C
• Storage: -20 to 60 °C
Humidity
• 0% to 80% non-condensing
Compatible KVM cables*
• DKVM-CU/B
• DKVM-CU3/B
• DKVM-CU5/B
* NOTE! The KVM cables of hardware revision B are compatible only with the KVM-440 KVM switch of hardware revision C.
Sertifikaadid
Sidustooted
KVM-440  8-Port KVM Switch with VGA and USB Ports
Pildid
KVM-440/Cx
Eestvaade
Eestvaade
Tagantvaade
Failid
Vaadake samuti
