KVM-402EOL
PS2 KVM cable for KVM-440/450 switches, 3 m
Kirjeldus
3 m KVM Cable KVM-402 is designed to connect a monitor, keyboard and mouse and it is compatible with D-Link DKVM series switch. KVM-402 is a set of "four in one" cables, which includes a VGA cable (with 15-pin HDD male connectors) for VGA monitor connection, and a USB 2.0 cable for connection between computer and KVM switch.
KVM-402 is a "four in one" cable. It saves space on a desktop, as it integrates several cables into one. Each cable has a color code (PC99), providing proper connection. Each cable also has a special screen with ferrite core, which reduces electromagnetic (EMI) and radiofrequency interference (RFI).
Põhiomadused
Connectors:
• VGA: 15-pin HDB male (monitor)
• USB: USB Type A male
• PS/2 (mouse): 6-pin mini-DIN male
• PS/2 (keyboard): 6-pin mini-DIN male
• KVM: 15-pin male
Physical parameters
Operating supply voltage
• 30 V
Cable length
• 3 m
Weight:
• 322 g
Sertifikaadid
Sidustooted
KVM-402 PS2 KVM cable for KVM-440/450 switches, 3 m
