DGS-1024D/GEEOL EOS
24-pordine 10/100/1000Base-T kommutaator energia säästmise funktsiooniga
Kirjeldus
The first D-Link Green technology on the market the DGS-1024D featuring innovative eco-friendly technology that helps
  • Reduce power consumption & generates less heat
  • Extend product life
  • Reduce operating costs
Note: D-Link Green Technology Only Available From DGS-1024D Rev. C1 And Above
Get the blazing speed of Gigabit Ethernet with the D-Link DGS-1024D, a 24-port 10/100/1000Mbps Switch that delivers power, performance, and reliability in one cost-effective, space-saving design. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Power users in the office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly. The versatile and compact 1RU height design of the DGS-1024D enables the device to be rackmounted in a standard 19 inch rack, while conserving valuable rack space.
Power-Packed
It features a non-blocking switching architecture that filters and forwards packets at full wire-speed for maximum throughput. An 8K MAC address table provides scalability for even the largest networks. Address learning and aging, 802.3x Flow Control for full-duplex mode, and back pressure flow control for half-duplex mode alleviates traffic congestion and ensures reliable data transmission. Designed using industry standards, it is compatible with virtually all 10, 100, and 1000Mbps Ethernet devices and other vendor equipment. It protects your existing network investments while providing you with a straightforward migration path to faster Gigabit speeds.
Easy to Install and Maintain
The auto features of this switch make installation plug & play and hassle-free. No configuration is required. Auto-MDI/MDI-X crossover on all ports eliminate the need for crossover cables for connection to another switch or hub. Auto-Negotiation on each port senses the link speed of a network device (either 10, 100, 1000Mbps) and intelligently adjusts for compatibility and optimal performance. It also features diagnostic LEDs, which display status and activity, allowing you to quickly detect and correct problems on the network. Every port also supports a cable diagnostic feature that helps to detect cable related problems.
*Power savings may vary depending on your network usage, products used and environment.
Põhiomadused
  • Innovatiivne Green Ethernet tehnoloogia
  • Taskukohane gigabitiline lahendus väikestele ja keskmistele ettevõtetele
  • 24 x 10/100/1000Base-T porti UTP Cat5
  • Кommutaatori tootlikkus: 48 Gbit/s
  • Kaabli polaarsuse automaatne tuvastamine MDI/MDIX
  • Kommutatsiooni meetod: store-and-forward
  • Pool-ja täisdupleksrežiimid Ethernet/Fast Ethernet kiirustele
  • Andmeedastuskiirus Gigabit Ethernet täisdupleksrežiimis: 2000 Мbit/s
  • Voojuhtimine IEEE 802.3x
  • Jumbo-freimide toetus 9600 baiti
  • IEEE 802.1p QoS toetus (4 järjekorda)
  • Kaablite diagnostika funktsioon
  • RoHS direktiivi vastavus
  • Plug-and-play
    Standardid
  • IEEE 802.3 10BASE-T Ethernet
  • IEEE 802.3u 100BASE-TX Fast Ethernet
  • IEEE 802.3ab 1000BASE-T Gigabit Ethernet
  • ANSI/IEEE 802.3 Nway
  • IEEE 802.1p QoS
    Portide arv
    24 x 10BASE-T/100BASE-TX/1000BASE-T porti
    Protokoll
    CSMA/CD
    Andmeedastuskiirus
  • Ethernet:
    • 10 Мbit/s (pooldupleks)
    • 20 Мbit/s (täisdupleks)
  • Fast Ethernet:
    • 100 Мbit/s (pooldupleks)
    • 200 Мbit/s (täisdupleks)
  • Gigabit Ethernet:
    • 2000 Мbit/s (täisdupleks)
    Topoloogia
    Täht
    Võrgukaablid
  • 10BASE-T:
    • UTP 3, 4, 5 (max 100 m)
    • EIA/TIA-586 100-ohm STP (max 100 m)
  • 100BASE-TХ, 1000BASE-T:
    • UTP 5, 5e (max 100 m)
    • EIA/TIA-568 100-ohm STP (max 100 m)
    Täis-/pooldupleks
  • Täis-/pooldupleksrežiim 10/100 Мbit/s
  • Täisdupleksrežiim Gigabit Ethernet jaoks
    Liides
    MDI/MDIX
    Indikaatorid
  • Pordile: 100Mbps/1000Mbps speed, Link/activity
  • Seadmele: Power
    Store-and-forward
    MAC-aadressite tabel
    8K kirjet seadmele
    MAC-aadressite uurimine
    Аutomaatne uuendamine
    Pakettide edastamine/filtreerimine (täisdupleksrežiimis)
  • Ethernet: 14,880pps pordile
  • Fast Ethernet: 148,800 pps pordile
  • Gigabit Ethernet: 1,488,100 pps pordile
    Buffermälu
    500 Кb
  • Sertifikaadid
    Sidustooted
    Pildid
    DGS-1024D/GE/A
    Eestvaade
    Tagantvaade
    Failid
    Vaadake samuti
