DGS-1005D/GEEOL EOS
5-pordine 10/100/1000Base-T kommutaator energia säästmise funktsiooniga
Kirjeldus
The DGS-1005D features innovative D-Link Green eco-friendly technology:
  • Reduces power consumption & creates less heat
  • Extended product life
  • Reduce operating costs
New and Improved
Announcing the next generation of D-Link Green power-saving technology. Now you can save up to 73%* power used for each switch.
Note: D-Link Green Technology Only Available From DGS-1005D Rev. D2 And Above
The D-Link GigaExpress DGS-1005D is a 5-port 10/100/1000Mbps Gigabit Switch that delivers power, performance, and reliability in one cost-effective, space-saving design. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality.
Power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly.
Power-Packed
The D-Link DGS-1005D 10/100/1000 Mbps Gigabit Switch features a non-blocking switching architecture that filters and forwards packets at full wire-speed for maximum throughput. An 1,000 MAC address table provides scalability for even the largest networks.
Address learning and aging, 802.3x Flow Control for full duplex mode, and back pressure flow control for half-duplex mode alleviates traffic congestion and ensures reliable data transmission. Designed using industry standards, it is compatible with virtually all 10, 100, and 1000Mbps Ethernet devices and other vendor equipment. The D-Link DGS-1005D 10/100/1000 Mbps Gigabit Switch protects your existing network investments while providing you with a straightforward migration path to faster Gigabit speeds.
Easy to use
The auto features of this gigabit switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDI-X crossover on all ports eliminate the need for crossover cables or uplink ports. Auto-negotiation on each port senses the link speed of a network device (either 10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance.
The switch also features diagnostic LEDs which display status and activity, allowing you to quickly detect and correct problems on the network.
*Power savings may vary depending on products used.
Põhiomadused
  • Innovatiivne Green Ethernet tehnoloogia
  • Taskukohane gigabitiline lahendus väikestele ja keskmistele ettevõtetele
  • 5 x 10/100/1000Base-T porti
  • Кommutatsiooni tootlikkus: 10 Гbit/s
  • Automaatne kaabli polaarsuse tuvastamine MDI/MDIX kõikidel portidel
  • Kommutatsiooni meetod: store-and-forward
  • Gigabit Ethernet andmeedastuskiirus täisdupleksrežiimis: 2000 Мbit/s
  • Voojuhtimine IEEE 802.3x
  • 9000 baitilite Jumbo-freimide toetus (ainult 1000 Мbit/s kiirusel)
  • IEEE 802.1p QoS toetus (4 järjekorda)
  • Kaablite diagnostika funktsioon
  • RoHS-ühilduv
  • Plug-and-play
    Standardid
  • IEEE 802.3 10BASE-T Ethernet
  • IEEE 802.3u 100BASE-TX Fast Ethernet
  • IEEE 802.3ab 1000BASE-T Gigabit Ethernet
  • ANSI/IEEE 802.3 Nway
  • IEEE 802.1p QoS
    Portide arv
  • 5 x 10BASE-T/ 100BASE-TX/ 1000BASE-T porti
    Protokoll
  • CSMA/CD
    Andmeedastuskiirus
  • Ethernet:
    • 10 Мbit/s (pooldupleks)
    • 20 Мbit/s (täisdupleks)
  • Fast Ethernet:
    • 100 Мbit/s (pooldupleks)
    • 200 Мbit/s (täisdupleks)
  • Gigabit Ethernet:
  • 2000 Мbit/s (täisdupleks)
    Тopoloogia
  • Täht
    Võrgukaablid
  • 10BASE-T:
    • UTP 3, 4, 5 (100 m maksimum)
    • EIA/TIA-586 100-ohm STP (100 m maksimum)
  • 100BASE-TХ, 1000BASE-T:
    • UTP 5, 5e (100 m maksimum)
    • EIA/TIA-568 100-ohm STP (100 m maksimum)
    Täisdupleks/pooldupleks
  • Täis-/pooldupleks režiim 10/100 Мbit/s jaoks
  • Täisdupleks režiim Gigabit Ethernet jaoks
    Laiendatud liidese võimalused
  • MDI/MDIX iga pordi jaoks
    Indikaatorid
  • Pordid: 100 Mbps/1000 Mbps speed, Link/activity
  • Seade: Power
  • Store-and-forward
    MAC-aadressite tabel
  • 1K kirjet seadmele
    MAC -aadressite uurimine
  • Аutomatne uuendamine
    Paketide üleandmine/filtreerimine (täisdupleks režiimis)
  • Ethernet: 14,880pps pordile
  • Fast Ethernet: 148,800 pps pordile
  • Gigabit Ethernet: 1,488,100 pps pordile
    RAM buffer
  • 106 Кbit seadmele
  • Sertifikaadid
    Sidustooted
    Pildid
    DGS-1005D/GE/GE
    Eestvaade
    Tagantvaade
    Failid
    Vaadake samuti
