DGS-1008D/GEEOL EOS
8 pordine 10/100/1000Base-T kommutaator energia säästmise funktsiooniga
Kirjeldus
The first D-Link Green technology on the market the DGS-1008D featuring innovative eco-friendly technology that helps
  • Reduce power consumption & generates less heat
  • Extend product life
  • Reduce operating costs
Note: D-Link Green Technology Only Available From DGS-1008D Rev. E3 And Above
Get the blazing speed of Gigabit Ethernet with the D-Link GigaExpress DGS-1008D, an 8-port 10/100/1000Mbps Gigabit Switch that delivers power, performance, and reliability in one cost-effective, space-saving design. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality.
Power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly.
Power-Packed
The D-Link DGS-1008D 10/100/1000 Mbps Gigabit Switch features a non-blocking switching architecture that filters and forwards packets at full wire-speed for maximum throughput. An 8,000 MAC address table provides scalability for even the largest networks. Address learning and aging, 802.3x Flow Control for full duplex mode, and back pressure flow control for half-duplex mode alleviates traffic congestion and ensures reliable data transmission.
Designed using industry standards, it is compatible with virtually all 10, 100, and 1000Mbps Ethernet devices and other vendor equipment. The D-Link DGS-1008D protects your existing network investment while providing you with a straightforward migration path to faster Gigabit network speeds.
Easy to Use
The auto features of this gigabit switch makes installation truly “plug and play” and hassle-free. No configuring is required. Auto MDI/MDI-X crossover on all ports eliminates the need for crossover cables or uplink ports. Auto-negotiation on each port senses the link speed of a network device (either 10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance.
It also features diagnostic LEDs which display status and activity, allowing you to quickly detect and correct problems on the network.
*Power savings may vary depending on your network usage, products used and environment.
Põhiomadused
  • Innovatiivne Green Ethernet tehnoloogia
  • Taskukohane gigabitiline lahendus väikestele ja keskmistele ettevõtetele
  • 8 x 10/100/1000Base-T porti
  • Коmmutaatori tootlikkus:16 Gbit/s
  • Kaabli polaarsuse tuvastamine MDI/MDIX kõikidel portidel
  • Kommutatsiooni meetod: store-and-forward
  • Pool- ja täisdupleksrežiimid Ethernet/Fast Ethernet kiirustele
  • Gigabit Ethernet andmeedastuskiirus täisdupleksrežiimis : 2000 Мbit/s
  • Voojuhtimine IEEE 802.3x
  • Jumbo-freimide toetus 9600 baiti
  • IEEE 802.1p QoS toetus (4 järjekorda)
  • Kaablite diagnostika funktsioon
  • RoHS-ühilduv
  • Plug-and-play
    Standardid
  • IEEE 802.3 10BASE-T Ethernet
  • IEEE 802.3u 100BASE-TX Fast Ethernet
  • IEEE 802.3ab 1000BASE-T Gigabit Ethernet
  • ANSI/IEEE 802.3 Nway
  • IEEE 802.1p QoS
    Portide arv
    8 x 10BASE-T/ 100BASE-TX/ 1000BASE-T porti
    Protokoll
    CSMA/CD
    Andmeedastuskiirus
  • Ethernet:
    • 10 Мbit/s (pooldupleks)
    • 20 Мbit/s (täisdupleks)
  • Fast Ethernet:
    • 100 Мbit/s (pooldupleks)
    • 200 Мbit/s (täisdupleks)
  • Gigabit Ethernet:
    • 2000 Мbit/s (täisdupleks)
    Тopoloogia
    Täht
    Võrgukaablid
  • 10BASE-T:
    • UTP 3, 4, 5 (100 m maksimaalselt)
    • EIA/TIA-586 100-ohm STP (100 m maksimaalselt)
  • 100BASE-TХ, 1000BASE-T:
    • UTP 5, 5e (100 m maksimaalselt)
    • EIA/TIA-568 100-ohm STP (100 m maksimaalselt)
    Täis-/pooldupleks
  • Täis-/pooldupleksrežiim 10/100 Мbit/s jaoks
  • Täisdupleksrežiim Gigabit Ethernet jaoks
     Indikaatorid
  • Pordil: 100Mbps/1000Mbps speed, Link/activity
  • Seadmel: Power
    Store-and-forward
    MAC-аaadressite tabel
    8K kirjet seadmele
    MAC -aadressite uurimine
    Аutomaatne uuendamine
    Paketide ülekandmine/filtreerimine (täisdupleksrežiimis)
  • Ethernet: 14,880pps pordile
  • Fast Ethernet: 148,800 pps pordile
  • Gigabit Ethernet: 1,488,100 pps pordile
    RAM buffer
    144 Кb seadmele
  • Sertifikaadid
    Sidustooted
    Pildid
    DGS-1008D/GE/A
    Eestvaade
    Tagantvaade
    Failid
    Vaadake samuti
