DES-3052EOL EOS
Kirjeldus
- High Port Density 10/100 Switch
- Optimized for Low Cost & Rich Features
- 4 Gigabit Uplink Capacity
- 4K VLAN & ACL Support
- Secure/Effective Management with RADIUS/TACACS+,Single IP Management, SSH/SSL Support
The DES-3052 has 48 Ethernet ports in low profile rack-mount case. The switch is equipped with 2 Gigabit uplinks, with the SFP supporting both fiber Gigabit and 100BASE-FX fiber connection for specific applications.
The DES-3052 supports many security features including Access Control List (ACL), 802.1X Port-Based/MAC-Based Access Control, 802.1X Guest VLAN, and RADIUS/TACACS+ authentication. To prevent malicious attack and virus/worm affection from overwhelming the switch with unnecessary workload, the DES-3052 provides D-Link Safeguard Engine and CPU Interface Filtering functions to increase the switch's reliability and availability.
To enhance network resilience, the DES-3052 provides Spanning Tree protocols, including 802.1D, 802.1w and 802.1s for redundant bridge paths. 802.3ad Link Aggregation provides the aggregated bandwidth between switches or server, For Quality of Service (QoS), it supports 802.1p Priority Queues and packet classification based on TOS, DSCP, MAC, IPv4, VLAN ID, Protocol type, User Defined Packet Content, enabling Internet voice, video and streaming media applications to run smoothly.
Network administrators can define throughput levels for each port to manage bandwidth. The bandwidth control feature provides fine granularity with the ability to define limits down to 64Kbps segments. Broadcast storm control can reduce the level of damage that a virus attack can do to the network. The switch provides IGMP snooping to control multicast transmission, and port mirroring to facilitate diagnostics.
The DES-3052 supports standard-based management protocols such as SNMP, RMON, Telnet, web-based GUI, SSH/SSL security authentication and DHCP Relay Option 82. With DHCP auto-configuration, the administrator can pre-set configurations and save them in a TFTP server; individual switches can boot their IP from the server and load in the pre-set configurations. D-Link Single IP Management simplifies and speeds up management tasks, allowing multiple switches to be configured, monitored and maintained from any workstation running a web browser through one unique IP address. A virtual stack of the DES-3028/3052 switches can be managed as a single object, with all units identified by a single IP address.
Põhiomadused
- Liidesed
- 48 x 10/100Base-TX porti
- 2 x 10/100/1000Base-T porti
- 2 kombo porti 10/100/1000Base-T /SFP
- Konsoolport RS-232
Tootlikkus - Kommutaatori sisemine lülituskiirus: 17.6 Gbit/s
- 64-baitilise paketi andmeedastuskiirus: 13.1 Mpps
- МАС-aadressite tabel: 8 К
- SDRAM CPU jaoks: 64 Мb
- Paketi bufferi suurus: 4 Мb
- Flash-mälu: 8 МB
- Jumbo-freimid (2048 baiti tagged, 2044 baiti untagged)
Indikaatorid - Toide
- Konsool
- Link/Activity
- Kiiruse indikaatorid
Tarkvaar
Teise kihi funktsioonid - IGMP Snooping v1, v2 (max. 256 gruppi)
- IGMP Snooping Fast Leave
- 802.1D Spanning Tree
- 802.1w Rapid Spanning Tree
- 802.1s Multiple Spanning Tree
- BPDU filtering
- STP Loopback Detection
- 802.3ad Link Aggregation:
8 porti igas grupis / 6 gruppi ühel seadmel - Portide peegeldamine (One to One, Many to One režiimid)
- Jumbo-freimide toetus
VLAN - 802.1Q
- Staatiliste VLAN gruppide arv – 4 К
- Dünaamiliste VLAN gruppide arv – 200
- GVRP
Teenuskvaliteet (QoS) - Prioriteetsuse järjekorrad 802.1p
- 4 prioriteetsuse järjekorda 802.1p
- WRR toetus / Strict mode
- Paketide klassifitseerimine:
- pordi number
- VLAN ID
- TCP/UDP pordi number
- МАС-aadress
- IP v4
- prioriteetsus 802.1р
- TOS
- DSCP
- protokolli tüüp
- paketi sisu
Pääsuloend
(max. 256 profiili / reeglit) - Mitmeastmelised ACL:
- Pordi number
- VLAN ID
- Prioriteetsus 802.1p
- МАС-aadress
- IPv4
- DSCP
- Protokolli tüüp
- Paketi sisu
- Aeg
Ligipääs / Turvalisus: - RADIUS/TACACS+ autentimine
- RADIUS kasutajatunnuste loomine
- Port security funktsioon (max. 16 MAC-aadressite kirjet pordi kohta)
- Pordipõhine ligipääsu juhtimine 802.1х
- MAC-aadressite põhine ligipääsu juhtimine 802.1х
- 802.1х Guest VLAN
- SSH v.1, v.2 / SSL v.3
- CPU Interface Filtering
- Liikluse segmentimine
- Broadcast tormi juhtimine
- D-Link Safeguard Engine
Ligipääsuriba juhtimine: - Kiiruse piiramine:
- kuni 2 Мb: sammuga 64 Кb
- kuni 100 Мb: sammuga 1 Мb
- rohkem kui 100 Мb: sammuga 8 Mb
Juhtimine - D-Link Single IP Management (SIM) v. 1.6
- Web-liides
- Käsurealiides (CLI)
- Telnet server/klient
- TFTP klient
- SNMP v.1, v.2c, v.3
- RMON v.1, v.2
- BootP/DHCP-klient
- SNTP
- SYSLOG
- Dual image
- Pordi kirjeldus
- Graafiline GUI Web-liides liikluse monitooringu jaoks / CPU
- SNMP trap on MAC notification
- DHCP Auto Configuration
- DHCP relay
- DHCP relay option 82
- SMTP klient (teatised e-maile)
MIB toetus - MIB II (RFC 1213)
- Bridge MIB (RFC 1493)
- SNMP v2 MIB (RFC 1907)
- RMON MIB (RFC 1757, 2819)
- RMON v2 MIB Probe config group (RFC 2021)
- Ether-like MIB (RFC 1643, 2358, 2665)
- 802.1p MIB (RFC 2674)
- IF MIB (RFC 2233, 2863)
- RADIUS Authentication Client MIB (RFC 2618)
- RADIUS Accounting Client MIB (RFC 2620)
- Ping & TRACEROUTE MIB (RFC 2925)
- Private MIB
Sertifikaadid
Sidustooted
DES-3052 2.kihi hallatav kommutaator, 48 x 10/100 Мbit/s porti + 2 x 1000BASE-T porti + 2 kombo porti 1000BASE-T/SFP
Võrguhaldustarkvara
DS-510S D-View 5.1 SNMP Network Management Program (standartne versioon)
DS-510P D-View 5.1 SNMP Network Management Program (professionaalne versioon)
Lisa SFP transiiverid
DEM-310GT SFP transiiver 1000BASE-LX, SMF, maksimaalne vahekaugus kuni 10 km, 3.3 V
DEM-311GT SFP transiiver 1000BASE-SX, MMF, maksimaalne vahekaugus kuni 550 m, 3.3 V
DEM-314GT SFP transiiver 1000BASE-LH, SMF, maksimaalne vahekaugus kuni 50 km, 3.3 V
DEM-315GT SFP transiiver 1000BASE-ZX, SMF, maksimaalne vahekaugus kuni 80 km, 3.3 V
DEM-210 SFP transiiver 100BASE-FX, SMF, maksimaalne vahekaugus kuni 15 km, 3.3 V
DEM-211 SFP transiiver 100BASE-FX, MMF, maksimaalne vahekaugus kuni 2 km, 3.3 V
Lisa WDM transiiverid
DEM-330T SFP transiiver 1000BASE-LX, SMF, maksimaalne vahekaugus kuni 10 km, 3.3 V, WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-330R SFP transiiver 1000BASE-LX, SMF, maksimaalne vahekaugus kuni 10 km, 3.3 V, WDM (Tx: 1310 nm, Rx:1550 nm)
DEM-331T SFP transiiver 1000BASE-LX, SMF, maksimaalne vahekaugus kuni 40 km, 3.3 V, WDM (Tx: 1550 nm, Rx: 1310 nm)
DEM-331R SFP transiiver 1000BASE-LX, SMF, maksimaalne vahekaugus kuni 40 km, 3.3 V, WDM (Tx: 1310 nm, Rx:1550 nm)
