Toote omadused:
Layer 2+ SmartPro Switch with 8 10GBase-T Ports and 2 10GBaseX SFP+ Ports |
Põhiomadused:
Interfaces
• 8 10GBase-T ports
• 2 SFP+ ports
• RJ-45 console port
Port Standard & Functions
• IEEE 802.3u 100Base-TX Fast Ethernet
• IEEE 802.3ab 1000Base-T Gigabit Ethernet
• IEEE 802.3az compliance
• IEEE 802.3an 10GBase-T 10 Gigabit Ethernet
• IEEE 802.3ae 10GbE over fiber
• IEEE 802.3z 1000Base-X
• Auto MDI/MDIX support for 1000/10GBase-T
Diagnostic LEDs
• Power
• Fan Error
• Console
• Link/Activity/Speed (Per 10GBase-T port)
• Link/Activity/Speed (Per 10G SFP+ port)
Network Cables for 10GBase-T
• Cat. 6 (30 m max)
• Cat. 6A or Cat. 7 (100 m max)
Media Interface Exchange
• Auto MDI/MDIX adjustment for all twisted-pair ports
Switching Capacity
• 200 Gbps
Maximum Packet Forwarding Rate
• 148.8 Mpps
Transmission Method
• Store-and-forward
MAC Address Table
• Up to 16K entries per device
Packet Buffer
• 2 Mbytes
Flash Memory
• 64 Mbytes
Software Features
L2 Features
• MAC Address Table: Up to 16K entries
• Static MAC Addresses: 1K
• IGMP Snooping:
IGMP v1/v2 Snooping
IGMP v3 awareness
Supports 384 IGMP groups
Supports at least 128 static multicast addresses
Per VLAN IGMP Snooping
Support host-based fast leave
• MLD Snooping:
MLD v1 Snooping
MLD v2 awareness
Support 384 groups
Support 128 static multicast addresses
• LLDP
• LLDP-MED
• Spanning Tree Protocol:
802.1D STP
802.1w RSTP
802.1s MSTP
• Flow Control:
802.3x Flow Control
HOL Blocking Prevention
• Port Mirroring:
One-to-One
Many-to-One
Supports Mirroring for Tx/Rx/Both
• 802.3ad Link Aggregation: Maximum of 8 groups/8 ports per group
• Jumbo Frame: Up to 9KB
• Loopback Detection
VLAN
• 802.1Q VLAN
• Port-based VLAN
• 4K VLAN Groups
• Configurable VID: 1~4094
• Voice VLAN
• Auto Surveillance VLAN
• GVRP*
• Asymmetric VLAN
Quality of Service (QoS)
• CoS based on:
802.1p Priority Queues
DSCP
ToS
IPv6 Traffic Class
TCP/UDP port
VLAN ID
MAC Address
Ether Type
IP Address
Protocol Type
IPv6 Flow Label
• 802.1p Priority Queue
• 8 queues per port
• Queue Handling:
Strict
Weighted Round Robin (WRR)
Deficit Round Robin (DRR)
Weighted Deficit Round Robin (WDRR)
Strict + WDRR
• Bandwidth Control:
Port-based (Ingress/Egress, min. granularity 64 Kbps)
iSCSI Awareness*
L3 Features
• IP Interface: Supports 8 IPv4/v6 interfaces
• ARP: 768 Static ARP
• Default Route
• Static Route:
Max. 64 IPv4 entries
Max. 64 IPv6 entries
Access Control List (ACL)
• Max. 50 access list
• Max. 256 ACL rules
• Max. 50 VLAN access map*
• ACL based on:
802.1p priority
VLAN*
MAC address
Ether type
IP address
DSCP
Protocol type
TCP/UDP port number
IPv6 Traffic Class
IPv6 flow label
Security
• Broadcast/Multicast/Unicast Storm Control
• D-Link Safeguard Engine
• DHCP Server Screening
• IP-MAC-Port Binding:
DHCP Snooping*
IP Source Guard*
Dynamic ARP Inspection*
IPv6 Snooping*
IPv6 Source Guard*
DHCPv6 Guard*
IPv6 ND Inspection*
IPv6 Route Advertisement (RA) Guard*
• Traffic Segmentation
• SSH*:
Support v1/ v2
Support IPv4/ IPv6
• SSL:
Support v1/v2/v3
Support IPv4/IPv6
• ARP Spoofing Prevention*: Max. 127 entries
• DoS Attack Prevention
• Port Security: Supports up to 6656 MAC addresses per port
• Duplicate Address Detection
Operations, Administration, and Management (OAM)
• Cable Diagnostics
Authentication, Authorization, and Accounting (AAA)
• Web-based Access Control (WAC)*:
Support local/RADIUS database
Support Port-based access control
Support Host-based access control
Support Dynamic VLAN Assignment
Identity-driven Policy (VLAN/ACL/QoS) Assignment
• 802.1X Authentication:
Supports local/RADIUS database
Supports Port-based access control
Supports Host-based access control
Supports EAP, OTP, TLS, TTLS, PEAP
• Support IPv4/IPv6 RADIUS Server
• Support IPv4/IPv6 TACACS+*
• Guest VLAN
• Compound Authentication*
• Authentication for management access
• Authentication Database Failover*
• MAC-based Access Control (MAC)*:
Management
• Web-based GUI
• D-Link Network Assistant Utility
• Full CLI
• Telnet Server
• TFTP Client
• Configurable MDI/MDIX
• SNMP: Supports v1/v2c/v3
• SNMP Trap
• Smart Wizard
• LLDP
• LLDP-MED
• DHCP Relay*
• System Log
• BootP/DHCP Client
• SNTP
• ICMP v6
• IPv4/v6 Dual Stack
• DHCP Auto Configuration*
• RMON v1/v2*
• Trusted Host
• Dual Images
• Dual Configurations
• DNS Client*
• Debug command
Green V3.0 Technology
• Power Saving by:
LED Shutoff
System Hibernation
Port Shutoff
MIB/RFC Standards
• RFC 783 TFTP
• RFC 951 BootP/DHCP Client
• RFC 1157 SNMP v1, v2, v3
• RFC 1213 MIB II
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1769 SNTP
• RFC 1542 BootP/DHCP Client
• RFC 1901 SNMP v1, v2, v3
• RFC 1907 SNMP v2 MIB
• RFC 1908 SNMP v1, v2, v3
• RFC 2131 BootP/DHCP Client
• RFC 2138 RADIUS Authentication*
• RFC 2139 RADIUS Authentication
• RFC 2233 Interface Group MIB
• RFC-2246 SSL
• RFC 2475
• RFC 2570 SNMP v1, v2, v3
• RFC 2575 SNMP v1, v2, v3
• RFC 2598 CoS
• RFC 2618 RADIUS Authentication*
• RFC 2819 RMON v1
• RFC 2865 RADIUS Authentication
• RFC 3164 System Log
• RFC 3195 System Log
• RFC 3411-17 SNMP
• D-Link Private MIB
• LLDP MIB
• Zone Defense MIB
• 2233 Interface Group MIB
Physical Parameters
Power Input
• 100 to 240 V AC
Maximum Power Consumption
• 68.67 W
Standby Power Consumption
• 31.59 W
Weight
• 3.1 kg
Dimensions
• 440 x 210 x 44 mm
Temperature
• Operating: -5° to 50°C
• Storage: -40° to 70°C
Humidity
• Operating: 0% to 95% non-condensing
• Storage: 0% to 95% non-condensing
Certifications
• CE
• FCC
• C-Ticket
• VCCI
• BSMI
• CCC
Safety
• cUL
• CB
• CE
• CCC
• BSMI
* This feature will be supported in a future firmware release.
Füüsilised parameetrid |
Vaadake samuti
