DGS-1510-28L/MEEOL EOS
24 10/100/1000 Mbps ports + 4 SFP ports Metro Ethernet Switch
Kirjeldus
	The DGS-1510/ME Series Metro Ethernet Switches are a family of Ethernet switches ideal for Metro Ethernet applications. They feature a variety of ports, including 10/100/1000BASE-T RJ-45 ports, 1G SFP ports, and 10G SFP+ ports for increased network bandwidth. Surge protection, advanced Layer 2 functions and a suite of security and management tools make the DGS-1510/ME Series Metro Ethernet Switches ideally suited for Metro Ethernet applications.
	Multi-Gigabit Performance
	The DGS-1510/ME Series Metro Ethernet Switches come with a variety of port types, including Gigabit Ethernet RJ-45, 1 Gigabit Ethernet SFP ports, or 10 Gigabit Ethernet SFP+ ports. All models offer a minimum of at least 2 Gigabit Ethernet SFP ports. The DGS-1510-28X/ME, DGS-1510-28XS/ME and DGS-1510-52/ME offer 4 10 Gigabit Ethernet SFP+ ports for improved uplink bandwidth. The DGS-1510-28LP/ME and DGS-1510-28XMP/ME switches feature PoE, allowing compatible devices to be installed in remote locations without immediate access to power outlets.
	Efficient and Resilient Networking
	All Ethernet ports in the DGS-1510/ME Series support 6 kV surge protection, protecting the switch from power surges due to lightning strikes or faulty electrical cabling. The switches can be used with a D-Link DPS-500A/DPS-500DC Redundant Power Supply (RPS) or a 12 VDC backup connection to ensure continuous operation. The DGS-1510/ME Series support ITU-T G.8032 Ethernet Ring Protection Switching (ERPS), which allows 50 millisecond failover in the event of a failure of one of the rings, minimizing service disruption. The switches also support IEEE 802.1AX and 802.3ad Link Aggregation, which allows grouping of multiple ports to provide redundancy and load balancing in mission-critical environments.
	Triple Play Services
	The DGS-1510/ME Series Metro Ethernet Switches feature a full suite of Layer 2 multicast functions, including IGMP snooping, IGMP filtering, fast leave, and multicast traffic configuration for specific ports. With L2 multicast support, the DGS-1510/ME Series is ready and capable of handling the growing demand for IPTV applications. Host-based IGMP/MLD Snooping allows for multiple multicast subscribers per physical interface, and an Internet Standard Multicast (ISM) VLAN separates multicast streams in a multicast VLAN, saving bandwidth on the backbone network. The ISM VLAN profiles allow users to bind the predefined multicast registration information to subscriber ports quickly and easily. The DGS-1510/ME Series also supports IGMP authentication, which can prevent rogue IPTV subscriptions by authenticating set-top boxes as well as channel switching to secure Internet Service Provider (ISP) revenues.
	Quality of Service
	The DGS-1510/ME Series supports advanced Quality of Service (QoS) functions to help ISPs reliably deliver high-quality triple play services. Flexible packet classification can be based on various header fields or user-defined packet content to help administrators prioritize network traffic. The Bandwidth Control feature allows ISPs to define the upstream/downstream throughput levels for each port with granularity down to 64 Kbps.
	Robust Maintenance and Troubleshooting
	The DGS-1510/ME Series feature a complete set of Operations, Administration, and Management (OAM) features to reduce maintenance costs and simplify management. Cable diagnostics display the status of Ethernet cables and allow support staff to detect cable errors remotely, reducing on-site support costs. The 802.3ah Ethernet Link OAM and 802.1ag Connectivity Fault Management (CFM) standards provide administrators with tools to effectively monitor and manage Ethernet networks. This allows service providers to monitor customer connectivity, isolate network issues and optimize network performance.
	Security & Authentication
	The DGS-1510/ME Series offer user and device authentication features such as 802.1X port-based access control and MAC address-based access control. This allows devices to be authenticated based on their MAC address, removing the need for client software and ensuring device compatibility. Host-based authentication and authorization provide the option to finely control network access for each device on the network. Advanced features such as RADIUS accounting allow the switches to be integrated with back-end systems for billing or advanced access control. The DGS-1510/ME Series support address and interface binding features such as IP-MAC-Port Binding and ARP Spoofing Prevention to protect against Man-in-the-Middle or ARP Spoofing attacks.
Põhiomadused
	Hardware Version
	• A1
	Interface
	Size
	• 19-inch standard rack-mount width
	• 1U height
	Interface
	• 24 10/100/1000 Mbps + 2 SFP
	Console Port
	• RJ-45 Console Port
	Port Standards & Functions
	• IEEE 802.3 10BASE-T Ethernet
	• IEEE 802.3u 100BASE-TX Fast Ethernet
	• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
	• IEEE 802.3x Flow Control for full-duplex mode, auto-negotiation
	Network Cables
	• UTP Cat. 5, Cat. 5e (100 m max.); EIA/TIA-568 100-ohm STP (100 m max.)
	Full/Half-Duplex
	• Full/half-duplex for 10/100 Mbps and Gigabit speed
	Media Interface Exchange
	• Auto or configurable MDI / MDIX
	Performance
	• Switching Capacity: 560 Gbps
	• Forwarding Method: Store-and-forward
	• MAC Address Table Size: Up to 16K entries per device
	• MAC Address Update: Up to 512 static MAC entries
	• Maximum 64-byte Max. Packet Forwarding Rate: 68.45 Mpps
	• Packet Buffer: 1.5 MB per device
	LEDs
	• Power (per device)
	• Redundant Power Supply (RPS) (per device)
	• Console (per device)
	• Link/Active/Speed (per port)
	Software Specifications
	Virtual Stacking
	• D-Link Single IP Management
	  - Up to 32 units per Virtual Stack
	L2 Features
	• MAC Address Table: Up to 16K
	• Flow Control
	  - 802.3x Flow Control
	  - HOL Blocking Prevention
	• Jumbo Frames up to 9216 Bytes
	• Spanning Tree Protocols
	  - 802.1D STP
	  - 802.1w RSTP
	  - 802.1s MSTP
	• BPDU Filtering
	• Root Restriction
	• Loopback Detection
	• Link Aggregation
	  - Compliant with 802.1AX and 802.3ad
	• Port Mirroring
	  - Supports 1 Mirroring group
	  - Supports One-to-One, Many-to-One, Flow-based (ACL)
	Mirroring
	• Ethernet Ring Protection Switching (ERPS)
	L2 Multicasting
	• IGMP Snooping
	  - IGMP v1/v2 Snooping, v3 awareness
	  - Supports 1024 groups
	  - Port/Host-based IGMP Snooping Fast Leave
	  - Report Suppression
	  - IGMP Authentication
	  - Limited IP Multicast (IGMP Filtering)
	• MLD Snooping
	  - MLD v1, MLD v2 awareness
	  - Port/Host-based MLD snooping Fast Leave
	VLAN
	• VLAN Group
	  - Max. 4094 VLAN
	• Port-based VLAN
	• MAC-based VLAN
	• GVRP
	  - Max. 255 dynamic VLANs
	• 802.1v Protocol VLAN
	• 802.1Q Tagged VLAN
	• Double VLAN (Q-in-Q)
	 - Port-based Q-in-Q
	• ISM VLAN
	• VLAN Translation
	• VLAN Trunking
	L3 Features
	• Max. 1024 ARP entries
	  - Supports 255 static ARP entries
	• Gratuitous ARP
	• 16 IP interfaces
	• Default Route
	• Static Route1
	  - 64 IPv4 static routes1
	  - 32 IPv6 static routes1
	• CoS based on
	  - Switch Port
	  - 802.1p Priority
	  - VLAN ID
	  - MAC Address
	  - Ether Type
	  - IPv4/IPv6 address
	  - DSCP
	  - ToS
	  - Protocol Type
	  - TCP/UDP Port
	  - IPv6 Traffic Class
	  - IPv6 Flow Label
	  - User Defined Packet Content
	• Bandwidth Control
	  - Port-based (Ingress, Min. Granularity 64 Kbps)
	  - Flow-based (Ingress, Min. Granularity 64 Kbps)
	  - Egress queue bandwidth control (Min. Granularity 64 Kbps)
	• Queue Handling
	  - Strict Priority Queue (SPQ)
	  - Weighted Round Robin (WRR)
	  - SPQ + WRR
	• 8 queues per port
	Access Control List (ACL)
	• ACL based on
	  - Switch Port
	  - 802.1p Priority
	  - VLAN ID
	  - MAC Address
	  - Ether Type
	  - IPv4/IPv6 Address
	  - IPv6 Flow Label
	  - DSCP
	  - ToS
	  - Protocol Type
	  - TCP/UDP Port
	  - User-defined Packet Content
	• Up to 1024 ingress access rules
	• Time-based ACL
	• ACL Statistics
	• CPU Interface Filtering
	AAA
	• 802.1X
	  - Port-based Access Control
	  - Host-based Access Control
	  - Dynamic VLAN Assignment
	• MAC-based Access Control (MAC)
	• Microsoft® NAP (IPv4)
	• Guest VLAN
	• RADIUS (IPv4)
	• TACACS (IPv4)
	• TACACS+ (IPv4)
	• XTACACS+ (IPv4)
	• Trusted Host
	• RADIUS Accounting
	• Four-level User Account
	Security
	• SSH v1/v2
	• SSL v1/v2/v3
	• Port Security
	  - Up to 64 MAC addresses per port
	• Broadcast/Multicast/Unicast Storm Control
	• IP-MAC-Port Binding (IMPB)
	  - ARP Inspection
	  - IP Inspection
	  - DHCP Snooping
	  - DHCPv6 Snooping1
	  - DHCPv6 Guard1
	  - IPv6 Route Advertisement (RA) Guard1
	  - IPv6 ND Snooping1
	  - IPv6 ND Inspection1
	• Traffic Segmentation
	• D-Link Safeguard Engine
	• L3 Control Packet Filtering
	• NetBIOS/NetBEUI Filtering
	• DHCP Server Screening
	• DHCP Client Filtering
	• ARP Spoofing Prevention
	• BPDU Attack Protection
	• DoS Attack Prevention
	OAM
	• Cable Diagnostics
	• 802.3ah Ethernet Link OAM
	• Dying Gasp
	Management
	• Web-based GUI (Supports IPv4/v6)
	• Command Line Interface (CLI)
	• Telnet Server/Client (Supports IPv4)
	• TFTP/FTP Client (Supports IPv4)
	• ZModem
	• Command Logging
	• SNMP v1/v2c/v3 (Supports IPv4)
	• SNMP Traps
	• System Log
	• SMTP (IPv4)
	• RMON v1:
	  - Supports 1,2,3,9 groups
	• RMON v2:
	  - Supports Probe Config group
	• 802.1AB LLDP
	  - LLDP-MED
	• BootP/DHCP Client (Supports IPv4)
	• DHCP Auto-Configuration1
	• DHCP Relay (Supports IPv4)
	  - DHCP Relay Option 60, 61 and 82
	  - DHCP Client Option 12
	• PPPoE Circuit-ID Tag Insertion1
	• Multiple Image
	• Flash File System
	• CPU Monitoring
	• Memory Monitoring
	• SNTP (Supports IPv4)
	• Debug Command
	• Password Recovery
	• Password Encryption
	• Ping
	• Traceroute
	• Microsoft® NLB (Network Load Balancing) Support (Supports IPv4)
	• Zero Touch Provisioning (ZTP)1
	• sFlow1
	• D-Link Network Assistant1
	Physical/Environmental
	MTBF
	• 635,099 hours
	Acoustic
	• N/A
	Heat Dissipation
	• 60.01 BTU/h
	Power Input
	• AC Input: 100 to 240 VAC 50/60 Hz
	Maximum Power Consumption
	• 17.6 W
	Standby Power Consumption
	• 10.1 W/100 V
	• 10.6 W/240 V
	Dimensions (W x D x H)
	• 440 x 210 x 44mm
	Weight
	• 2.00 kg
	Ventilation
	• Fanless
	Power Surge Protection
	• All Ethernet ports support IEC61000-4-5 6 kV surge protection
	Operating Temperature
	• -5 to 50 ˚C (23 to 122 ˚F)
	Storage Temperature
	• -20 to 70˚C (-4 to 158 ˚F)
	Operating Humidity
	• 0% to 95% non-condensing
	Storage Humidity
	EMI
	• CE, FCC, C-Tick, VCCI, BSMI
	Safety Certifications
	• cUL, CB
	1Feature available in a future software
Sertifikaadid
Sidustooted
	DGS-1510-28L/ME  24 10/100/1000 Mbps ports + 4 SFP ports Metro Ethernet Switch
	Redundant Power Supply and Cable
	DPS-500A  140 W Redundant Power Supply (Alternating Current)
	DPS-500DC  140 W Redundant Power Supply (Direct Current)
	DPS-CB150-2PS v.B1  150 cm RPS cable for connecting the DGS-1510/ME Series with the DPS-500A and DPS-500DC
	Optional SFP Transceivers
	DEM-310GT   1000BASE-LX, single-mode, 10 km
	DEM-311GT  1000BASE-SX, multi-mode, 550 m
	DEM-312GT2  1000BASE-SX, multi-mode, 2 km
	DEM-314GT  1000BASE-LHX, single-mode, 50 km
	DEM-315GT  1000BASE-ZX, single-mode, 80 km
	DGS-712 1000BASE-T to SFP transceiver
	Optional WDM SFP Transceivers
	DEM-331T  1000BASE-LX, wavelength Tx: 1550 nm, Rx: 1310 nm, single-mode, 40 km
	DEM-331R  1000BASE-LX, wavelength Tx: 1310 nm, Rx: 1550 nm, single-mode, 40 km
	DEM-330T  1000BASE-LX, wavelength Tx 1550 nm, Rx 1310 nm, single-mode, 10 km
	DEM-330R  1000BASE-LX, wavelength Tx 1310 nm, Rx 1550 nm, single-mode, 10 km
	DEM-302S-BXD  1000BASE-LX, wavelength Tx:1550 nm Rx:1310 nm, Single-mode, 2 km
	DEM-302S-BXU  1000BASE-LX, wavelength Tx:1310 nm Rx:1550 nm, Single-mode, 2 km
	Optional SFP+ Transceivers
	DEM-431XT  10GBASE-SR SFP+ Transceiver (without DDM), 33 m: OM1 MMF, 82 m: OM2 MMF, 300 m: OM3 MMF
	DEM-431XT-DD  10GBASE-SR SFP+ Transceiver (with DDM), 33 m: OM1 MMF, 82 m: OM2 MMF, 300 m: OM3 MMF
	DEM-432XT  10GBASE-LR SFP+ Transceiver (without DDM), 10 km
	DEM-432XT-DD  10GBASE-LR SFP+ Transceiver (with DDM), 10 km
	DEM-433XT  10GBASE-ER SFP+ Transceiver (without DDM), 40 km
	DEM-433XT-DD  10GBASE-ER SFP+ Transceiver (with DDM), 40 km
	DEM-434XT  10GBASE-ZR SFP+ Transceiver (without DDM), 80 km
	DEM-436XT-BXD  10GBASE-LR BiDi SFP+ Transceiver (without DDM), Wavelength Tx 1330 nm, Rx: 1270 nm, 20 km
	DEM-436XT-BXU  10GBASE-LR BiDi SFP+ Transceiver (without DDM), Wavelength Tx 1270 nm, Rx: 1330 nm, 20 km
