Kiirotsing
Toote omadused:
24 10/100/1000 Mbps ports + 4 SFP ports Metro Ethernet Switch
Põhiomadused:
Hardware Version
• A1
Interface
Size
• 19-inch standard rack-mount width
• 1U height
Interface
• 24 10/100/1000 Mbps + 2 SFP
Console Port
• RJ-45 Console Port
Port Standards & Functions
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
• IEEE 802.3x Flow Control for full-duplex mode, auto-negotiation
Network Cables
• UTP Cat. 5, Cat. 5e (100 m max.); EIA/TIA-568 100-ohm STP (100 m max.)
Full/Half-Duplex
• Full/half-duplex for 10/100 Mbps and Gigabit speed
Media Interface Exchange
• Auto or configurable MDI / MDIX
Performance
• Switching Capacity: 560 Gbps
• Forwarding Method: Store-and-forward
• MAC Address Table Size: Up to 16K entries per device
• MAC Address Update: Up to 512 static MAC entries
• Maximum 64-byte Max. Packet Forwarding Rate: 68.45 Mpps
• Packet Buffer: 1.5 MB per device
LEDs
• Power (per device)
• Redundant Power Supply (RPS) (per device)
• Console (per device)
• Link/Active/Speed (per port)
Software Specifications
Virtual Stacking
• D-Link Single IP Management
  - Up to 32 units per Virtual Stack
L2 Features
• MAC Address Table: Up to 16K
• Flow Control
  - 802.3x Flow Control
  - HOL Blocking Prevention
• Jumbo Frames up to 9216 Bytes
• Spanning Tree Protocols
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
• BPDU Filtering
• Root Restriction
• Loopback Detection
• Link Aggregation
  - Compliant with 802.1AX and 802.3ad
• Port Mirroring
  - Supports 1 Mirroring group
  - Supports One-to-One, Many-to-One, Flow-based (ACL)
Mirroring
• Ethernet Ring Protection Switching (ERPS)
L2 Multicasting
• IGMP Snooping
  - IGMP v1/v2 Snooping, v3 awareness
  - Supports 1024 groups
  - Port/Host-based IGMP Snooping Fast Leave
  - Report Suppression
  - IGMP Authentication
  - Limited IP Multicast (IGMP Filtering)
• MLD Snooping
  - MLD v1, MLD v2 awareness
  - Port/Host-based MLD snooping Fast Leave
VLAN
• VLAN Group
  - Max. 4094 VLAN
• Port-based VLAN
• MAC-based VLAN
• GVRP
  - Max. 255 dynamic VLANs
• 802.1v Protocol VLAN
• 802.1Q Tagged VLAN
• Double VLAN (Q-in-Q)
 - Port-based Q-in-Q
• ISM VLAN
• VLAN Translation
• VLAN Trunking
L3 Features
• Max. 1024 ARP entries
  - Supports 255 static ARP entries
• Gratuitous ARP
• 16 IP interfaces
• Default Route
• Static Route1
  - 64 IPv4 static routes1
  - 32 IPv6 static routes1
Quality of Service (QoS)
• CoS based on
  - Switch Port
  - 802.1p Priority
  - VLAN ID
  - MAC Address
  - Ether Type
  - IPv4/IPv6 address
  - DSCP
  - ToS
  - Protocol Type
  - TCP/UDP Port
  - IPv6 Traffic Class
  - IPv6 Flow Label
  - User Defined Packet Content
• Bandwidth Control
  - Port-based (Ingress, Min. Granularity 64 Kbps)
  - Flow-based (Ingress, Min. Granularity 64 Kbps)
  - Egress queue bandwidth control (Min. Granularity 64 Kbps)
• Queue Handling
  - Strict Priority Queue (SPQ)
  - Weighted Round Robin (WRR)
  - SPQ + WRR
• 8 queues per port
Access Control List (ACL)
• ACL based on
  - Switch Port
  - 802.1p Priority
  - VLAN ID
  - MAC Address
  - Ether Type
  - IPv4/IPv6 Address
  - IPv6 Flow Label
  - DSCP
  - ToS
  - Protocol Type
  - TCP/UDP Port
  - User-defined Packet Content
• Up to 1024 ingress access rules
• Time-based ACL
• ACL Statistics
• CPU Interface Filtering
AAA
• 802.1X
  - Port-based Access Control
  - Host-based Access Control
  - Dynamic VLAN Assignment
• MAC-based Access Control (MAC)
• Microsoft® NAP (IPv4)
• Guest VLAN
• RADIUS (IPv4)
• TACACS (IPv4)
• TACACS+ (IPv4)
• XTACACS+ (IPv4)
• Trusted Host
• RADIUS Accounting
• Four-level User Account
Security
• SSH v1/v2
• SSL v1/v2/v3
• Port Security
  - Up to 64 MAC addresses per port
• Broadcast/Multicast/Unicast Storm Control
• IP-MAC-Port Binding (IMPB)
  - ARP Inspection
  - IP Inspection
  - DHCP Snooping
  - DHCPv6 Snooping1
  - DHCPv6 Guard1
  - IPv6 Route Advertisement (RA) Guard1
  - IPv6 ND Snooping1
  - IPv6 ND Inspection1
• Traffic Segmentation
• D-Link Safeguard Engine
• L3 Control Packet Filtering
• NetBIOS/NetBEUI Filtering
• DHCP Server Screening
• DHCP Client Filtering
• ARP Spoofing Prevention
• BPDU Attack Protection
• DoS Attack Prevention
OAM
• Cable Diagnostics
• 802.3ah Ethernet Link OAM
• Dying Gasp
Management
• Web-based GUI (Supports IPv4/v6)
• Command Line Interface (CLI)
• Telnet Server/Client (Supports IPv4)
• TFTP/FTP Client (Supports IPv4)
• ZModem
• Command Logging
• SNMP v1/v2c/v3 (Supports IPv4)
• SNMP Traps
• System Log
• SMTP (IPv4)
• RMON v1:
  - Supports 1,2,3,9 groups
• RMON v2:
  - Supports Probe Config group
• 802.1AB LLDP
  - LLDP-MED
• BootP/DHCP Client (Supports IPv4)
• DHCP Auto-Configuration1
• DHCP Relay (Supports IPv4)
  - DHCP Relay Option 60, 61 and 82
  - DHCP Client Option 12
• PPPoE Circuit-ID Tag Insertion1
• Multiple Image
• Flash File System
• CPU Monitoring
• Memory Monitoring
• SNTP (Supports IPv4)
• Debug Command
• Password Recovery
• Password Encryption
• Ping
• Traceroute
• Microsoft® NLB (Network Load Balancing) Support (Supports IPv4)
• Zero Touch Provisioning (ZTP)1
• sFlow1
• D-Link Network Assistant1
Physical/Environmental
MTBF
• 635,099 hours
Acoustic
• N/A
Heat Dissipation
• 60.01 BTU/h
Power Input
• AC Input: 100 to 240 VAC 50/60 Hz
Maximum Power Consumption
• 17.6 W
Standby Power Consumption
• 10.1 W/100 V
• 10.6 W/240 V
Dimensions (W x D x H)
• 440 x 210 x 44mm
Weight
• 2.00 kg
Ventilation
• Fanless
Power Surge Protection
• All Ethernet ports support IEC61000-4-5 6 kV surge protection
Operating Temperature
• -5 to 50 ˚C (23 to 122 ˚F)
Storage Temperature
• -20 to 70˚C (-4 to 158 ˚F)
Operating Humidity
• 0% to 95% non-condensing
Storage Humidity
EMI
• CE, FCC, C-Tick, VCCI, BSMI
Safety Certifications
• cUL, CB
1Feature available in a future software
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
